boundary conditions in FLUENT VOF for open channel flow |
March 24, 2011, 04:04 |
Gillian
Rep Power: 15 |
Hi guys,
I have been working on the simulation of flow in a channel through a baffle using VOF FLUENT. I encountered a few problems and would appreciate it if you could please give me some suggestions: Currently I am using two separate inlets for water and air. The BC for air is set as pressure inlet. I have tried 3 types of BC for water (pressure-inlet, mass flow, and velocity - as the velocity is known) but the simulation somehow gave me a flow direction that looks like the water flows from outlet back to the inlet. The outlet is set as 1 outlet (for both water and air) and operated as pressure outlet. The top surface of air is also set as pressure outlet. I am wondering if there is some problems with my current setting ? Your suggestions are very much appreciated. Gillian |
March 24, 2011, 04:36 |
mohsen
Rep Power: 15 |
hi.
you should not separate the inlet or outlet for water and air.it's better to use OPEN CHANNEL FLOW by switch it's toggle on and set the inlet and outlet as PRESSURE INLET/OUTLET one and entered your data.also it's better too use ''explicit'' method {define>models>multiphase.....} good lock. |
March 26, 2011, 08:03 |
Gillian
Rep Power: 15 |
hi momech,
Thanks a lot for the suggestion! |
April 5, 2011, 00:58 |
Gillian
Rep Power: 15 |
I tried the simulation with one inlet for the two phase but could not get the results right. The solution still did not converge and another serious issue is the results gave me reverse flow at the inlet. My boundary conditions are: 1. inlet: pressure inlet, with specifying the flow depth at the inlet 2. outlet: pressure outlet, with flow depth specified (which is lower than in the inlet, due to pressure drop across the baffle) 3. upperbound : I have tried either pressure outlet and symmetry. Would appreciate it very much if anyone please give me some suggestions on how to solve the problem of reverse flow at the inlet during the simulation. Indeed, I tried to use velocity inlet as BC for inlet. However, I am a bit confused of how to come up with the volume fraction of water and air respectively (in my physical model, the flow is at 0.04 m/s). Besides, it seemed that with velocity inlet, I could not initialize using open channel initialization. Can anyone give me some suggestions on how should i set velocity inlet BC for open channel ? Thanks a lot! Gillian |
April 5, 2011, 08:08 |
mohsen
Rep Power: 15 |
Hi newcomer
I did the 3D open channel case with cutwater and get acceptable results, it seems that you didn't patch your desired area/volume with water and its velocity after initialize. best regards. |
April 16, 2013, 18:13 |
#6 | |
Moahanad
Rep Power: 13 |
anyone can help me with setting the boundary conditions in the open channel flow? Thanks |
April 16, 2013, 18:18 |
Moahanad
Rep Power: 13 |
did u figure out the problem, if u did, could u help me. Thank you.
June 2, 2013, 08:32 |
#8 | |
FHydro
Rep Power: 13 |
I am using "Open channel flow" option in inlet and outlet boundaries. It is look like water goes up in pressure inlet boundary. Where is the origin of the free surface and bottom. Is it in bottom of any boundary or origin of coordinates? help me please. |
June 3, 2013, 03:07 |
#9 | |
Rep Power: 13 |
please read "Heave and Pitch Simulation of Ship hull moving through head sea waves" tutorial |
June 6, 2013, 14:23 |
#10 |
Moahanad
Rep Power: 13 |
Thank you for replying. Could you please send me the tutorial, I can't find it. Thank you for your help.
June 10, 2013, 11:19 |
#11 |
OJ
Rep Power: 20 |
Can you post you email address? I can sent it across to you.
OJ |
June 10, 2013, 13:18 |
#12 |
Moahanad
Rep Power: 13 |
mkhdcpu1@yahoo.com Thank you for your help
June 10, 2013, 13:53 |
#13 |
FHydro
Rep Power: 13 |
saeed.azsh88@gmail.com thank you
July 7, 2013, 04:33 |
#14 |
Bhargav
Rep Power: 13 |
ybhargav93@gmail.com thank u
July 17, 2013, 02:51 |
#15 |
tomo umor
Rep Power: 12 |
tomo.umor@gmail.com thanks for help
July 22, 2013, 16:37 |
#16 |
Derek Foran
Rep Power: 12 |
servicesamigo@gmail.com If it's still out there, thanks!
July 29, 2013, 04:38 |
#17 |
July 29, 2013, 11:58 |
#18 |
Derek Foran
Rep Power: 12 |
I have not received it yet either, I guess it no longer is out there
August 10, 2013, 03:46 |
#19 |
mostafa shamsi
Rep Power: 12 |
August 25, 2013, 09:05 |
#20 |
JAY
Rep Power: 12 |
I have some problem with my boundary condition that how i utilize the neumann condition(∂φ/∂x = 0) at outlet. Can i select pressure outlet at outlet?
my inlet condition is : flat velocity profile =40m/s Re=1.916*10^5 turbulent intensity=4.5% And Inlet height of duct=5mm I select velocity inlet at inlet because my flow is incompresible. And axis boundary condition applied along the centerline. and no slip condition at wall. pls help me. |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Free surface flow settubg boundary conditions and plotting velocity profiles | prashanthreddyh | FLUENT | 2 | October 21, 2015 09:58 |
boundary conditions for 3D channel flow with heat transfer | Aloex | FLUENT | 1 | February 22, 2011 12:28 |
Proper Pressure Boundary Conditions for Buoyant Flow | mchurchf | OpenFOAM | 0 | March 25, 2010 12:16 |
Open Channel Boundary Conditions via journal | Matteo | FLUENT | 0 | January 21, 2008 11:05 |
