July 5, 2012, 06:00 |
Running a UDF only once per timestep
Alex
Rep Power: 46 |
Is there any possibility to tun a UDF (like DEFINE_SOURCE for example) only ONCE every timestep and not on every iteration?
July 6, 2012, 04:03 |
Daniel Tanner
Rep Power: 18 |
Try this:
if ( first_iteration ) { enter your calculations here } I got this from: http://willem.engen.nl/uni/fluent/do...ips-Tricks.pdf Let me know how it goes. |
July 6, 2012, 07:57 |
Either what Daniel suggested or you can use the macro EXECUTE_AT_END. Depends on your need, whether you want to execute at beginning or at the end of a time-step.
DEFINE_EXECUTE_AT_END(name) { ... } DEFINE_EXECUTE_AT_END is a general-purpose macro that is executed at the end of an iteration in a steady state run, or at the end of a time step in a transient run. https://www.sharcnet.ca/Software/Flu...udf/node22.htm |
UDF using c_face_loop(c,t,i) | frederic | FLUENT | 3 | January 16, 2017 23:17 |
parse error while interpreting udf | Kristin | Fluent UDF and Scheme Programming | 3 | March 15, 2012 06:43 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 10:16 |
I need UDF help. | S.Whitney | FLUENT | 0 | October 15, 2007 11:29 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
