UDF mass transfer
Old   March 2, 2013, 19:26
Default UDF mass transfer
cfd^2
cfd^2 is on a distinguished road
Hi everyone,
I've a question about interphase mass transfer in FLUENT using an Eulerian framework. I'm using Eulerian-Eulerian model, but I am planning to do some tests with mixture model and VOF model as well.
I wrote a UDF to calculate the interphase flux as follows:
DEFINE_MASS_TRANSFER(mass_source_0, cell, thread, from_index,from_species_index, to_index, to_species_index)
real m_lg_0;
m_lg_0 = C_UDMI(cell, thread, 0);
return (m_lg_0);
"C_UDMI(cell, thread, 0)" is provided by a DEFINE_ADJUST macro, i.e. applied to the whole multiphase domain (right?).
My question is if it adequately represents the interphase exchange, or there is some additional requirement to be included in the code? Have anyone worked with this kind of modeling?
Best Regards.
cfd^2 is offline   Reply With Quote
Old   March 2, 2013, 20:36
cfd^2
I checked elsewhere that a guy recommended to use the following structure to "mark" the region of mass transfer, taking into account just the interface... It stands for something like this:
real m_lg_0;
if ((C_VOF(cell,thread) != 0) && (C_VOF(cell,thread) !=1))
return (m_lg_0);
I tried to run it, but FLUENT tells me that I got an ACCESS VIOLATION... Is this approach valid... if yes, could anyone tell me what is wrong (why I'm violating FLUENT access?)...
Please, help me....
Old   March 3, 2013, 05:15
SSL
msaeedsadeghi is on a distinguished road
The problem is with C_UDMI. Where have you defined it?
msaeedsadeghi is offline   Reply With Quote
Old   March 3, 2013, 07:11
cfd^2
In a DEFINE_ADJUSt macro that is compiled along with the DEFINE_MASS_TRANSFER one.
Old   March 3, 2013, 23:54
SSL
The whole UDF should be investigated.
Old   May 23, 2013, 17:35
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
C_UDMI only works inside a cell loop I believe. You can try and see if that works out for you.
begin...
C_UDMI(c,t,i);
end_c_loop(c,t)
pranab_jha is offline   Reply With Quote
Old   May 24, 2013, 01:27
Shashank
shashank312 is on a distinguished road
The line marked in red in your post #2 does not necessarily define the interface.
Secondly, the "thread" here is a mixture thread and your VOF command cannot be passed over a mixture thread. You have to use a THREAD_SUB_THREADS function to locate the phase thread for which the VOF is being calculated.
Also, I would advise you to share the adjust routine if you want folks to help you out here.
shashank312 is offline   Reply With Quote
Old   May 28, 2013, 13:00
Default running in parallel mass_trasfer udf
Kanarya is on a distinguished road
Hi
I have problem to run in parallel this code?It is simple C_UDMI which is calculated before:
DEFINE_MASS_TRANSFER(water1,c,t,from_index, from_species_index, to_index, to_species_index)
#if !RP_HOST
return(C_UDMI(c,t,10));
#endif
in serial it is ok but parallel giving me following error:
warning C4716: 'water1' : must return a value.
is there anyone had expericed before?
Thanks in advance!!!
Kanarya is offline   Reply With Quote
Old   May 28, 2013, 14:18
Default Phase thread
pranab_jha's Avatar
Pranab N Jha
Shashank312 is spot on! You have to define the fluid interface correctly using VOF_G(radient) macro and also use the phase thread instead of the mixture thread.
@Kanarya
I have used C_UDMI in parallel and did not get any errors. But to let you know, I ran in batch mode over a remote server using a pbs (batch job) file.
Listing the pbs script file here, if it is of any use:
#!/bin/bash
#PBS -l nodes=2pn=1
module add fluent
cd $PBS_O_WORKDIR
cp /home/* .
/cm/shared/apps/Fluent.Inc/bin/fluent 2d -t2 -g -ssh -mpi=hp -cnf=$PBS_NODEFILE -i file.jou
The line starting with "cp" does the trick of copying all variables for parallel processing (Note the space between {*} and {.} at the end of the same line). Of course, you will have to use the -t2 in the last line for specifying the number of processors.
Old   May 28, 2013, 17:20
Hi pranab_jha,
thanks for quick answer!
OK!
did you use #if !RP_HOST or #if !RP_NOPE?
or you did not use any of them..
is it working without parallelising?
Thanks again for the answer!
#!/bin/bash
#PBS -l nodes=2pn=1
module add fluent
cd $PBS_O_WORKDIR
cp /home/* .
The line starting with "cp" does the trick of copying all variables for parallel processing (Note the space between {*} and {.} at the end of the same line). Of course, you will have to use the -t2 in the last line for specifying the number of processors.[/QUOTE]
Old   May 29, 2013, 10:56
Default parallel consideration
  #11
pranab_jha's Avatar
Pranab N Jha
Originally Posted by Kanarya View Post
Hi pranab_jha,
OK!
[/QUOTE]
I think the problem might be that you are trying to return a value from one of the nodes that does not generate the UDMI value. In serial, the value is being generated by THE only node. But not in parallel.
I think you might try using !RP_NODE. That will ensure that only the host process is returning the data. Let us know if that works. I used the UDMI (a while back) in parallel, but used it regardless of the NODE or HOST. So, it gave me an output for each node. So, for example, for each time step, I had multiple values of either 0 or non-zero from each node. Later, I had to filter the values out in Matlab. You are doing it the right way!
Old   November 16, 2013, 12:13
Wink
  #12
mehdimoradi
mehdimoradi. is on a distinguished road
I have a question about mass transfer in multiphase problems;
we have used DEFINE-MASS TRANSFER macro for species transport from solid phase to gas phase as a udf, recently. I want to know this udf is updated in each iteration or not? if not what work must be done to do this?
Tashakor
mehdimoradi. is offline   Reply With Quote
mass transfer in ANSYS thipps ANSYS 1 August 29, 2013 11:05
Simulation with UDF for species mass fraction and velocity profile virgy Fluent UDF and Scheme Programming 8 February 7, 2012 04:30
Multiphase Multicomponent mass transfer -Initial condition pannsave CFX 10 February 9, 2011 01:12
Mass Transfer UDF using Fluent VOF Anirudh_Deodhar FLUENT 0 February 7, 2011 15:10
Help with mass transfer in heat and water vapor exchanger mullenc525 CFX 7 January 25, 2011 23:26
