How to locate all the edge node by UDF?
Old   August 5, 2013, 12:00
Default How to locate all the edge node by UDF?
Edison
hadesmajesty is on a distinguished road
Hi, I want to implement Womersley velocity profile on inlet of a 3D vessel. However, the inlet face is not strictly a circle, so I need to map a profile for circle to the non-regular inlet face. The implementation involves finding the nodes on the edges of inlet face, which means the nodes on the vessel inlet and vessel wall.
I am wondering if there are any Fluent udf macro can do this or how to write a code to locate (get the coordinate) all the edge nodes? Thank you in advance.
hadesmajesty is offline   Reply With Quote
Old   August 7, 2013, 03:52
Paritosh Vasava
vasava will become famous soon enough
Have a look at macro C_FACE.
Also look at these pages
http://www.sharcnet.ca/Software/Flue...udf/node94.htm
vasava is offline   Reply With Quote
How to get the Global Node Number by UDF : Fluent Yusuke FLUENT 1 October 23, 2015 10:55
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
I need UDF help. S.Whitney FLUENT 0 October 15, 2007 11:29
Node values on UDF??? Kamal FLUENT 1 December 10, 1999 10:37
