Enquiry about hooking keff UDF into Fluent
Old   February 26, 2014, 00:54
Question Enquiry about hooking keff UDF into Fluent
dotapro is on a distinguished road
In what place I should hook in my keff (effective thermal conductivity) UDF into Fluent as I failed to find any option?
dotapro is offline   Reply With Quote
Old   February 26, 2014, 04:00
pakk will become famous soon enough
You want to change a material property, so look under the 'materials' tab.
There is no reason to use a bigger fontsize like you did. It makes you look aggressive, like you are shouting.
pakk is offline   Reply With Quote
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 13, 2017 23:23
How can i check that my UDF is being used in fluent istead of its internal data chemkin Fluent UDF and Scheme Programming 4 June 8, 2012 08:07
10 reactions udf hooking m&s FLUENT 0 July 6, 2010 00:36
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 03:07
