March 1, 2014, 08:45 |
UDF help
Rep Power: 14 |
I wanna put a log wind speed profile at inlet for ABL flow modelling
It's a 3D case I wonder which thread I should use. cell thread or face thread Thanks in advance |
March 1, 2014, 14:56 |
Rep Power: 17 |
In my opinion face thread,
March 1, 2014, 15:26 |
A-A Azarafza
Rep Power: 14 |
When you talk about profile, you must define your UDF in thread except the case you want to fix values in a specific zone. In this case, you can use C_PROFILE and flag on the cell zones.
Regard yours |
March 2, 2014, 09:59 |
Rep Power: 14 |
Thanks for your reply
A little bit further discussion when I declare x in real, should x be ND_ND or (ND_ND)*(ND_ND) in my case Normally x[1] is for y direction and x[2] is for z direction In my case, the square inlet contains lots of faces in either y or z direction |
March 2, 2014, 10:02 |
#5 | |
Rep Power: 14 |
I only want a velocity profile at inlet, that's every enough for me to avoid complication I dont quite get your point in c_profile and flag Do you mind clarifying them in detail Many thanks |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 06:12 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
