2 degree of freedom in one direction UDF
Like Tree1Likes
  • 1 Post By ghost82
Old   March 3, 2014, 10:24
Default 2 degree of freedom in one direction UDF
Linh Tuan The Nguyen
linh nguyen is on a distinguished road
I am doing simulation for flow around free oscillating cylinder. The cylinder was attach with the mass by spring which can be consider as 2 DOF system in one direction (y direction) not 1DOF for each (x, y direction).
I using SDOF in Fluent for single degree of freedom case and it was working fine. But when it's come to 2 DOF, I have no idea how to start.
I am very grateful if anybody can give me some suggestion how to start.
Best Regards
linh nguyen is offline   Reply With Quote
Old   March 5, 2014, 05:53
ghost82's Avatar
Rick
ghost82 will become famous soon enough
You can use the 6dof solver and create an udf with body properties and use the following lines to have restricted motion:
Transational motion in x direction is not allowed:
prop[SDOF_ZERO_TRANS_X] = TRUE;
Transational motion in x direction is allowed:
prop[SDOF_ZERO_TRANS_X] = FALSE;
Transational motion in y direction is not allowed:
prop[SDOF_ZERO_TRANS_Y] = TRUE;
Transational motion in y direction is allowed:
prop[SDOF_ZERO_TRANS_Y] = FALSE;
Transational motion in z direction is not allowed:
prop[SDOF_ZERO_TRANS_Z] = TRUE;
Transational motion in z direction is allowed:
prop[SDOF_ZERO_TRANS_Z] = FALSE;
Rotational motion around x axis is not allowed:
prop[SDOF_ZERO_ROT_X] = TRUE;
Rotational motion around x axis is allowed:
prop[SDOF_ZERO_ROT_X] = FALSE;
Rotational motion around y axis is not allowed:
prop[SDOF_ZERO_ROT_Y] = TRUE;
Rotational motion around y axis is allowed:
prop[SDOF_ZERO_ROT_Y] = FALSE;
Rotational motion around z axis is not allowed:
prop[SDOF_ZERO_ROT_Z] = TRUE;
Rotational motion around z axis is allowed:
prop[SDOF_ZERO_ROT_Z] = FALSE;
Daniele
linh nguyen likes this.
ghost82 is offline   Reply With Quote
Old   March 7, 2014, 05:50
Thank Daniele,
I have used this SDOF Macro already for Single degree of cylinder system I have done before and I quite familiar with SDOF Macro. But now I am doing 2DOF in 1 direction, that, the cylinder in the flow domain will be attached with a Mass (see attachment). Do you think in Fluent they have a Macro for this or I have to write my own UDF for this case.
Linh
cylinder, dynamic mesh
looping UDF in given direction ak6g08 Fluent UDF and Scheme Programming 0 September 10, 2009 10:13
degree of freedom ztdep Main CFD Forum 1 January 12, 2009 08:16
changing gravity vector direction using UDF Nico FLUENT 0 September 7, 2006 12:00
6 Degree of Freedom Navier Stoke Equations Apollo Main CFD Forum 6 July 21, 2004 16:46
Definition of degree of freedom Multiscaleman Main CFD Forum 2 June 11, 2004 07:58
