problem during compiling UDF
Old   October 5, 2017, 08:56
Default problem during compiling UDF
musab
ned.musab is on a distinguished road
Hello everyone...
I am working on a 3D wind turbine airfoil. My objective is to oscillate(like sinusoidal wave) the wing from -15 to +15 degrees along the chord length at point 0.25 meters.
The chord length of my airfoil is 1 meter.
The problem is during compiling the udf.It gives the following error when i click BUILD tab:
Copied C:\Users\name\Desktop\New folder1\xyz_files\dp0\FFF\Fluent/C:\Users\name\Desktop\New folder1\xyz_files\dp0\FFF\Fluent\UDF(AOA).c to libudf\src
(system "copy "C:\PROGRA~1\ANSYSI~1\v140\fluent"\fluent14.0.0\sr c\makefile_nt.udf "libudf\win64\3ddp\makefile" ")
1 file(s) copied.
(chdir "libudf")()
(chdir "win64\3ddp")()
'nmake' is not recognized as an internal or external command,
operable program or batch file.
Done.
And when i click on LOAD tab is gives error below:
The UDF library you are trying to load (C:\Users\name\Desktop\New folder1\xyz_files\dp0\FFF\Fluent\libudf) is not compiled for 3ddp on the curent platform (win64).
The system cannot find the file specified.
C:\Users\name\Desktop\New folder1\xyz_files\dp0\FFF\Fluent\C:\Users\name\Des ktop\New folder1\xyz_files\dp0\FFF\Fluent\libudf\win64\3ddp \libudf.dll
Need help.Thanks!
ned.musab is offline   Reply With Quote
Old   October 11, 2017, 10:48
Default Hi!
Kuldeep
ksingh is on a distinguished road
There might be problem with your visual studio. You can fix it.
ksingh is offline   Reply With Quote
Problem with UDF for CG Circular Motion luthlau Fluent UDF and Scheme Programming 1 September 16, 2016 02:08
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 08:51
Problem with compiling UDF in Fluent amojodi Fluent UDF and Scheme Programming 4 April 14, 2015 09:01
HELP! Problem compiling UDF function Syrakus FLUENT 6 April 7, 2006 10:48
UDF compiling problem for 3D simulation Marijo FLUENT 1 March 28, 2006 03:21
