can UDF change the boundary type or turbulence model?
Old   January 28, 2015, 21:15
Default can UDF change the boundary type or turbulence model?
Haoting Wang
hotin87 is on a distinguished road
I am trying to change the turbulence model I am using depending on the flow speed. For example, I want to use a laminar model when flow speed is 0, and a realizable k-e model when the flow speed is 4 m/s. If possible, how can we do that through UDF?
hotin87 is offline   Reply With Quote
Old   January 29, 2015, 07:12
upeksa is on a distinguished road
It is not possible by UDF. It might be possible by an interaction scheme-UDF, but it seems quite complex.
I can't help you, I don't know a lot about scheme.
Anyway, what you are trying, if it is possible and you can implement it, I think that I will not be numerically stable, besides it does not make sense to me.
If I where you, I would check in your ANSYS Fluent manual the chapter called "How do I choose my turbulent model", for further information.
upeksa is offline   Reply With Quote
Old   January 29, 2015, 09:23
Haoting Wang
Do you think it would be numerically unstable if I keep changing the models? But if the real condition is like a process have both larminar and turbulent flows at different time, would it be OK if I just use the turbulence model?
Old   January 30, 2015, 03:23
pakk will become famous soon enough
Doesn't the turbulent model give nearly similar results as the laminar model when you apply it to a laminar situation?
In that case I would just use the turbulent model everywhere. You will use some unnecessary computation time on calculating the (small) turbulence in the laminar zones, but I would not worry about that.
pakk is offline   Reply With Quote
Old   January 30, 2015, 10:19
Haoting Wang
The results are different, I don't understand why. I thought in the turbulence model, when velocity is low, there are some mechanism that can depress the turbulence model. But it looks it's not like that.
The attached figure show the difference. It plots the temperature, the upper one is using a laminar model, the lower one is using a turbulence model. The velocity is 0. All the other boundary conditions are the same.
Old   January 30, 2015, 15:28
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Did you try the rng k-epsilon?
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   January 30, 2015, 17:26
Haoting Wang
I see, the correct initial value of k and e seems very important, I used 1 as the initial value before. Looks like that is not correct.
inlet pressure is higher than outlet pressure for fan sivakumar OpenFOAM Pre-Processing 16 December 30, 2017 14:16
Simulation won't show turbulence pete_87 OpenFOAM Running, Solving & CFD 4 June 25, 2014 11:35
T Junction Stability ignacio OpenFOAM Running, Solving & CFD 5 May 2, 2013 10:44
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 14:16
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
