How to choose surface of just one material?
Old   April 26, 2017, 01:41
Default How to choose surface of just one material?
h0rst is on a distinguished road
Hello everyone,
I have a 3D model including a rectangular cross-section (pipe flowed through by water).
When I choose this surface by GUI using iso-clip, I have the whole cross-section (solid and fluid) but I only want to select the nodes of the solid.
How can I select that? Do I need to use UDF?
Best regards
h0rst
h0rst is offline   Reply With Quote
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Comsol (4.3): convert parametric surface into block? sgalaz COMSOL 0 November 9, 2012 09:20
