Which macro yields the absolute pressure value?
Like Tree3Likes
  • 1 Post By CeesH
  • 2 Post By CeesH
Old   April 13, 2015, 05:43
Default Which macro yields the absolute pressure value?
shivakumar is on a distinguished road
From the solution data it is possible to obtain absolute pressure value at each node or cell center. In FLUENT manual I couldn't find the macro for absolute pressure.
Which macro yields the absolute pressure value.?
Thanks in advance
shivakumar is offline   Reply With Quote
Old   April 13, 2015, 05:59
Cees Haringa
CeesH is on a distinguished road
Isn't C_P(c,t) the absolute pressure?
If it is the relative, add the operating pressure to it and you're good to go right?
shivakumar likes this.
CeesH is offline   Reply With Quote
Old   April 13, 2015, 06:07
Thanks for the reply.
I guess it is a static pressure value but I'm not sure..
But in the solution data, there are absolute, total, static pressure, etc values are available so only confused to access absolute pressure.
Old   April 13, 2015, 06:46
Cees Haringa
Maybe you want to check out the FLUENT user manual, section 7.14.
All pressures that you specify and all pressures computed or reported by ANSYS Fluent are gauge pressures.
So I'd guess the pressure reported by the macro is indeed a gauge pressure.
Then:
P_abs = P_operating + P_gauge. So, to get the absolute pressure, simply add the macro to the operating pressure.
To differentiate a bit more clear:
Static pressure: The static gauge pressure
Dynamic pressure: Velocity pressure (0.5*density*velocity)
absolute pressure: total static pressure; the gauge + operating pressure
total pressure: dynamic + static gauge pressure
Does this answer your question?
shivakumar and yijecho like this.
Old   April 13, 2015, 11:23
Smile
U have solved my doubt. I got it. Thank you very much ..
negative absolute pressure ahmadi FLUENT 0 May 23, 2014 08:54
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 12:43
Difference between pressure, absolute pressure and Total Pressure shaswat CFX 1 September 6, 2012 06:12
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
about large minus absolute pressure richard FLUENT 3 December 6, 2003 09:39
