How to use UDF to get the Global courant number at time in fluent 14.0?
Old   August 18, 2015, 11:05
Smile How to use UDF to get the Global courant number at time in fluent 14.0?
Fangdian
fangdian is on a distinguished road
Dear everyone:
I used the fluent 14.0 to simulation the transient welding pool, in which I applied the adaptive time step(transient VOF model). I set the Global courant number to 2.And the Global courant number is also been solved and displayed in simulation after every time step in the message window.
If I want to get the Global courant number at time by UDF, how Can I do?
Best regards !
fangdian is offline   Reply With Quote
Old   August 18, 2015, 19:33
`e`
`e` is on a distinguished road
If Fluent doesn't hold the current global Courant number in a variable somewhere then you could find this value yourself. Loop through all of the nodes or cells and find the highest value for this Courant number.
`e` is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 09:08
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
