How to use UDF to get the Global courant number at time in fluent 14.0? |
August 18, 2015, 11:05 |
Fangdian
Rep Power: 13 |
Dear everyone:
I used the fluent 14.0 to simulation the transient welding pool, in which I applied the adaptive time step(transient VOF model). I set the Global courant number to 2.And the Global courant number is also been solved and displayed in simulation after every time step in the message window. If I want to get the Global courant number at time by UDF, how Can I do? Best regards ! |
August 18, 2015, 19:33 |
Rep Power: 18 |
If Fluent doesn't hold the current global Courant number in a variable somewhere then you could find this value yourself. Loop through all of the nodes or cells and find the highest value for this Courant number.
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
