UDF to fix the pressure in domain - not working
Like Tree2Likes
  • 1 Post By Far
  • 1 Post By Far
Old   August 16, 2015, 23:58
Default UDF to fix the pressure in domain - not working
Far
Sijal
Hi Every One
I am trying to fix the pressure in domain using DEFINE_EXECUTE_AT_END macro for the journal bearing simulation.
Although I am able to solve it using the cavitation model along with mixture model, but there are some variables for which I don't have info, for example vaporization pressure...therefore I am preferring the first method...
Here is the UDF I am using (got it from this forum in some thread), but it is not fixing static pressure in domain as intended i.e. I want to make the static pressure at end of each iteration to zero...
Here are the results i am getting after each iteration (some random iteration)
File Type: c halfpressure.c (361 Bytes, 25 views)
Dinesh_Dhande likes this.
Old   August 17, 2015, 04:47
Far
Sijal
It is working now . Thanks every one
moon shine likes this.
Old   July 24, 2017, 09:34
Duyikang
DuYikang is on a distinguished road
hello,I am glad to know you success.Now, i am encountering the same difficult.Can you tell me how to change the negative pressure into zero?Thanks a lot!
DEFINE_ADJUST(adjust_pressure,domain)
Thread *t;
cell_t c;
thread_loop_c(t,domain)
begin_c_loop(c,t)
if(C_P(c, t) < 0)
C_P(c, t) = 0;
end_c_loop(c,t)
DuYikang is offline   Reply With Quote
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
pulsatile blood flow - developing larger pressure in the fluid domain KushalJ CFX 4 April 29, 2015 00:14
UDF to set velocity and pressure in inlet GerardX89 Fluent UDF and Scheme Programming 0 July 16, 2012 10:15
how to get pressure and pressure gradient using UDF Honglin Fluent UDF and Scheme Programming 0 May 24, 2012 06:47
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
