UDF problem
Old   October 22, 2015, 07:43
Unhappy UDF problem
gau
LAMAINA GAUDENZIO
gau is on a distinguished road
hi, I have a problem with UDF, I CAN FILL MY UDF, BUT WHEN RUN CALCULATION FLUENT NOT START ITERATION.
THE ERROR THAT IS PRESENTED IS THIS:
ERROR: RECEIVED A FATAL SIGNAL (SEGMENTATION FAULT)
ERROR OBJECT: #f
How can I solve the problem???
thanks
this is mY UDF
THE FIRST PART OF INITIALIZATION is OK
THE PROBLEM IS IN X_MOMENTUM
DEFINE_SOURCE(x_momentum,c,t,dS,eqn)
real x[ND_ND];
int p,s,ip,is;
float a,ia;
int iz;
real phi,phideg,alfa,alfar,deltaR;
real Wr,Wt,Wz,Wtz;
real m,Re,mu;
float valDp,valDs,valLp,valLs;
real CL,CD,Cr,Ct,Cx,Cy,Cz;
real Sref;
float Ci,Ctot,CP,Ti,Ttot,CT;
real Vcorretto;
FILE *fp1;
C_CENTROID(x,c,t);
if(N_ITER<iterazione+1)
RA[c]=x[1]-y0;
for (j=0;j<NRB;j++)
if(RA[c]>raggio[j])
p=j;
s=p+1;
a=(RA[c]-raggio[p])/(raggio[s]-raggio[p]);
betaR[c]=a*(beta[s]-beta[p])+beta[p];
cordaR[c]=a*(corda[s]-corda[p])+corda[p];
deltaR=intervallo/nlivelli;
jr[c]= (nlivelli-(R-RA[c]-deltaR/2)/deltaR)-1+1e-1;
Wr=C_V(c,t);
Wt=C_W(c,t)-(RA[c]*omega);
Wz=C_U(c,t);
Wtz=sqrt(pow(Wt,2)+pow(Wz,2));
phi=atan(-Wz/Wt);
phideg=phi/M_PI*180;
alfa=phideg-betaR[c]-degpitch;
alfar=alfa*M_PI/180;
iz=jr[c];
alfav[iz]=alfar;
alfadeg[iz]=alfa;
if (alfadeg[iz]<0)
Message("ATTENZIONE: alfa è negativo! alfadeg=%f per la cella %d\n",alfadeg[iz],iz);
m=Wtz/sqrt(1.4*287.1*288.71);
mu=1.7894e-5;
Re=C_R(c,t)*cordaR[c]*Wtz/mu;
p=0;
for(j=0; j<NNC-1; j++)
if (Re>Rey[j])
p=j;
s=p+1;
ia=alfadeg[iz];
ip=floor(ia)-indiceN;
is=ip+1;
if(RA[c]>(R-intervallo) && RA[c]<R1)
valDp=(matrD1[ip][s]-matrD1[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD1[ip][p];
valDs=(matrD1[is][s]-matrD1[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD1[is][p];
valLp=(matrL1[ip][s]-matrL1[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL1[ip][p];
valLs=(matrL1[is][s]-matrL1[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL1[is][p];
if (Re<Rey[0])
valDp=matrD1[ip][p];
valDs=matrD1[is][p];
valLp=matrL1[ip][p];
valLs=matrL1[is][p];
if (Re>Rey[NNC-1])
valDp=matrD1[ip][s];
valDs=matrD1[is][s];
valLp=matrL1[ip][s];
valLs=matrL1[is][s];
CD=(valDs-valDp)*(ia-indiceN-ip)+valDp;
CL=(valLs-valLp)*(ia-indiceN-ip)+valLp;
if(RA[c]>R1 && RA[c]<R2)
valDp=(matrD2[ip][s]-matrD2[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD2[ip][p];
valDs=(matrD2[is][s]-matrD2[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD2[is][p];
valLp=(matrL2[ip][s]-matrL2[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL2[ip][p];
valLs=(matrL2[is][s]-matrL2[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL2[is][p];
if (Re<Rey[0])
valDp=matrD2[ip][p];
valDs=matrD2[is][p];
valLp=matrL2[ip][p];
valLs=matrL2[is][p];
if (Re>Rey[NNC-1])
valDp=matrD2[ip][s];
valDs=matrD2[is][s];
valLp=matrL2[ip][s];
valLs=matrL2[is][s];
if(RA[c]>R2 && RA[c]<R3)
valDp=(matrD3[ip][s]-matrD3[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD3[ip][p];
valDs=(matrD3[is][s]-matrD3[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD3[is][p];
valLp=(matrL3[ip][s]-matrL3[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL3[ip][p];
valLs=(matrL3[is][s]-matrL3[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL3[is][p];
if (Re<Rey[0])
valDp=matrD3[ip][p];
valDs=matrD3[is][p];
valLp=matrL3[ip][p];
valLs=matrL3[is][p];
if (Re>Rey[NNC-1])
valDp=matrD3[ip][s];
valDs=matrD3[is][s];
valLp=matrL3[ip][s];
valLs=matrL3[is][s];
if(RA[c]>R3 && RA[c]<R4)
valDp=(matrD4[ip][s]-matrD4[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD4[ip][p];
valDs=(matrD4[is][s]-matrD4[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD4[is][p];
valLp=(matrL4[ip][s]-matrL4[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL4[ip][p];
valLs=(matrL4[is][s]-matrL4[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL4[is][p];
if (Re<Rey[0])
valDp=matrD4[ip][p];
valDs=matrD4[is][p];
valLp=matrL4[ip][p];
valLs=matrL4[is][p];
if (Re>Rey[NNC-1])
valDp=matrD4[ip][s];
valDs=matrD4[is][s];
valLp=matrL4[ip][s];
valLs=matrL4[is][s];
if(RA[c]>R4 && RA[c]<R5)
valDp=(matrD5[ip][s]-matrD5[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD5[ip][p];
valDs=(matrD5[is][s]-matrD5[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD5[is][p];
valLp=(matrL5[ip][s]-matrL5[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL5[ip][p];
valLs=(matrL5[is][s]-matrL5[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL5[is][p];
if (Re<Rey[0])
valDp=matrD5[ip][p];
valDs=matrD5[is][p];
valLp=matrL5[ip][p];
valLs=matrL5[is][p];
if (Re>Rey[NNC-1])
valDp=matrD5[ip][s];
valDs=matrD5[is][s];
valLp=matrL5[ip][s];
valLs=matrL5[is][s];
if(RA[c]>R5 && RA[c]<R6)
valDp=(matrD6[ip][s]-matrD6[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD6[ip][p];
valDs=(matrD6[is][s]-matrD6[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD6[is][p];
valLp=(matrL6[ip][s]-matrL6[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL6[ip][p];
valLs=(matrL6[is][s]-matrL6[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL6[is][p];
if (Re<Rey[0])
valDp=matrD6[ip][p];
valDs=matrD6[is][p];
valLp=matrL6[ip][p];
valLs=matrL6[is][p];
if (Re>Rey[NNC-1])
valDp=matrD6[ip][s];
valDs=matrD6[is][s];
valLp=matrL6[ip][s];
valLs=matrL6[is][s];
if(RA[c]>R6 && RA[c]<R7)
valDp=(matrD7[ip][s]-matrD7[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD7[ip][p];
valDs=(matrD7[is][s]-matrD7[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD7[is][p];
valLp=(matrL7[ip][s]-matrL7[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL7[ip][p];
valLs=(matrL7[is][s]-matrL7[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL7[is][p];
if (Re<Rey[0])
valDp=matrD7[ip][p];
valDs=matrD7[is][p];
valLp=matrL7[ip][p];
valLs=matrL7[is][p];
if (Re>Rey[NNC-1])
valDp=matrD7[ip][s];
valDs=matrD7[is][s];
valLp=matrL7[ip][s];
valLs=matrL7[is][s];
if(RA[c]>R7 && RA[c]<R8)
valDp=(matrD8[ip][s]-matrD8[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD8[ip][p];
valDs=(matrD8[is][s]-matrD8[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD8[is][p];
valLp=(matrL8[ip][s]-matrL8[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL8[ip][p];
valLs=(matrL8[is][s]-matrL8[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL8[is][p];
if (Re<Rey[0])
valDp=matrD8[ip][p];
valDs=matrD8[is][p];
valLp=matrL8[ip][p];
valLs=matrL8[is][p];
if (Re>Rey[NNC-1])
valDp=matrD8[ip][s];
valDs=matrD8[is][s];
valLp=matrL8[ip][s];
valLs=matrL8[is][s];
if(RA[c]>R8 && RA[c]<R9)
valDp=(matrD9[ip][s]-matrD9[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD9[ip][p];
valDs=(matrD9[is][s]-matrD9[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD9[is][p];
valLp=(matrL9[ip][s]-matrL9[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL9[ip][p];
valLs=(matrL9[is][s]-matrL9[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL9[is][p];
if (Re<Rey[0])
valDp=matrD9[ip][p];
valDs=matrD9[is][p];
valLp=matrL9[ip][p];
valLs=matrL9[is][p];
if (Re>Rey[NNC-1])
valDp=matrD9[ip][s];
valDs=matrD9[is][s];
valLp=matrL9[ip][s];
valLs=matrL9[is][s];
if(RA[c]>R9 && RA[c]<R10)
valDp=(matrD10[ip][s]-matrD10[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD10[ip][p];
valDs=(matrD10[is][s]-matrD10[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrD10[is][p];
valLp=(matrL10[ip][s]-matrL10[ip][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL10[ip][p];
valLs=(matrL10[is][s]-matrL10[is][p])/(Rey[s]-Rey[p])*(Re-Rey[p])+matrL10[is][p];
if (Re<Rey[0])
valDp=matrD10[ip][p];
valDs=matrD10[is][p];
valLp=matrL10[ip][p];
valLs=matrL10[is][p];
if (Re>Rey[NNC-1])
valDp=matrD10[ip][s];
valDs=matrD10[is][s];
valLp=matrL10[ip][s];
valLs=matrL10[is][s];
Cr=0;
Ct=-CD*cos(phi)+CL*sin(phi);
Cy=0;
Cz=Ct;
Cx=CD*sin(phi)+CL*cos(phi);
Sref=-B*cordaR[c]*C_R(c,t)*pow(Wtz,2)/(4.*M_PI*deltaX*RA[c]);
USx[c]=Cx*Sref;
USy[c]=Cy*Sref;
USz[c]=Cz*Sref;
Vcorretto=C_VOLUME(c,t)*2*M_PI;
if(WSTflag==1)
fp1 = fopen("dati.dat","a");
if (c==0)
fprintf (fp1, "c jr x[0] x[1] RA VOLUME Vx Vy Vz Wtz m Re phi beta alfa USx USy USz Cx Cy Cz Ct Cr CL CD\n");
fprintf (fp1, "%d %d %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f\n",c,jr[c],x[0],x[1],RA[c],Vcorretto,C_U(c,t),C_V(c,t),C_W(c,t),Wtz,m,Re,phi deg,betaR[c],alfa,USx[c],USy[c],USz[c],Cx,Cy,Cz,Ct,Cr,CL,CD);
fclose(fp1);
if (c==0)
Ctot=0.;
Ttot=0.;
Ci=((x[1]-y0)*USz[c])*Vcorretto;
Ti=USx[c]*Vcorretto;
Ctot=Ctot+Ci;
Ttot=Ttot+Ti;
if (c==NNP-1)
CP=-Ctot*omega*2./(C_R(c,t)*pow(fabs(Vinf),3)*M_PI*pow(R,2));
CT=-Ttot*2./(C_R(c,t)*pow(fabs(Vinf),2)*M_PI*pow(R,2));
Message("termini sorgente stampati\n");
Message("Ctot=%g omega=%g Ttot=%g C_R(c,t)=%g Vinf=%g\n", Ctot,omega,Ttot,C_R(c,t),Vinf);
Message("Il CP per lambda %g vale %g\n",lambda,CP);
Message("Il CT per lambda %g vale %g\n",lambda,CT);
fprintf (fp1, "\nAlla iterazione %d \n",N_ITER);
fprintf (fp1, "Ctot= %g omega= %g Ttot= %g C_R(c,t)= %g Vinf= %g \n", Ctot,omega,Ttot,C_R(c,t),Vinf);
fprintf (fp1, "Il CP per lambda %g vale %g\n",lambda,CP);
fprintf (fp1, "Il CT per lambda %g vale %g\n\n",lambda,CT);
fclose(fp1);
return USx[c];
DEFINE_SOURCE(y_momentum,c,t,dS,eqn)
real x[ND_ND];
C_CENTROID(x,c,t);
return USy[c];
DEFINE_SOURCE(z_momentum,c,t,dS,eqn)
real x[ND_ND];
C_CENTROID(x,c,t);
return USz[c];
gau is offline   Reply With Quote
Old   October 22, 2015, 08:12
pakk will become famous soon enough
You are trying to access a memory that is not assigned.
Most probably a USy for a c that was not defined.
Maybe you did not define USy for all c? Maybe there is a c for which RA[c]>R10?
It would be much more clear if your write your code differently. Now you have:
This is much more clear as:
if(RA[c]<(R-intervallo))
{ [what should happen here? not defined in your code...]}
else if (RA[c]<R1)
else if(RA[c]<R2)
else if(RA[c]<R3)
else if(RA[c]<R4)
else if(RA[c]<R5)
else if(RA[c]<R6)
else if(RA[c]<R7)
else if(RA[c]<R8)
else if(RA[c]<R9)
else if(RA[c]<R10)
else
Make sure that you cover ALL cases.
pakk is offline   Reply With Quote
Old   October 22, 2015, 12:49
gau
LAMAINA GAUDENZIO
I don't write this UDF, but but it has been used in other works. I think the problem is my work but I do not know what can be the cause of my error!!
Old   October 23, 2015, 07:16
I am not your boss or supervisor, so for me it does not matter who wrote the UDF.
And therefore you asked it here, and you got an answer from me. Am I missing something? Did my reply of yesterday not appear on your screen?
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 08:51
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 15:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 10:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
