Distribution of temperature
Like Tree2Likes
  • 1 Post By `e`
  • 1 Post By pakk
Old   January 10, 2016, 06:11
Default Distribution of temperature
George
fnatic09 is on a distinguished road
Hello Guys, I've created a simple code which is used to show symmetrical temperature distribution on a disc. But it's only symmetrical in one axis direction. How to change a code to make a circular distribution in all directions not only in one axis ? Is it possible ? I've tried to enter a circle equation but it's not working..
#include "udf.h"
DEFINE_PROFILE(inlet_x_temperature, thread, position)
real x[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
if(y<=0)
F_PROFILE(f, thread, position) = 300-y;
else
F_PROFILE(f, thread, position) = 300+y;
end_f_loop(f, thread)
fnatic09 is offline   Reply With Quote
Old   January 10, 2016, 20:27
`e`
`e` is on a distinguished road
You're currently setting the temperature profile as T(y) = |y| + 300 which agrees well with your result (independent of x).
For a radial temperature profile you must first calculate the radial component r = \sqrt{(x^2 + y^2)} (assuming the origin is at (x,y) = (0,0)) and then T(r) = r + 300.
An example code snippet:
F_PROFILE(f, thread, position) = sqrt(x[0]*x[0] + x[1]*x[1]) + 300.;
fnatic09 likes this.
`e` is offline   Reply With Quote
Old   February 13, 2016, 04:40
George
Everything's working fine but now I have a question how to change equation to get parabolic and circular (in all sides) temperature distribution. I attach an image to show what exactly I mean.
Regards
Old   February 15, 2016, 09:05
pakk will become famous soon enough
Look again at what `e` typed, but use a different equation for T.
For example: T(r)=300+r^2.
(Or, including units: T(r)=300 K+1 K m^{-2} \cdot r^2.)
pakk is offline   Reply With Quote
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
temperature distribution inside droplet? ljp Fluent UDF and Scheme Programming 1 June 7, 2017 01:38
Indoor Air Temperature distribution - convergence problem Shogan FLUENT 4 May 8, 2014 02:07
how to show the temperature distribution of the mould thomasyangfly FLOW-3D 2 August 26, 2012 09:21
unsteady temperature distribution over coupled bc in MultiRegionCase mvoss OpenFOAM Running, Solving & CFD 0 December 29, 2010 05:17
