UDF residence time distribution
Old   January 21, 2016, 07:30
Smile UDF residence time distribution
Liam
Many is on a distinguished road
Hi CFD friends!
I am trying to compute residence time contours using UDF found in this forum
My questions are the following:
1. Changing the mesh, then the residence time contours change (at least the maximum of residence time). I guess this is not desirable. Anybody has an idea about why this is happening? I realized that mesh cells appear in the function...
I am wondering if achieving mesh independent results will fix this, it's to said, max_residence_time tends to real_max_residence_time as cell_size tends to zero
If not, I am not understanding the value of this UDF as residence time will be mesh-dependent...
2. Which values should I use for Schmidt number and mass diffusivity for water?
3. When I got convergent results, I just solve for the defined scalar in steady state. Is unsteady solution needed? In other words, have I switch to unsteady model just for solving the scalar transport?
I have asked in another threads and I have found no answer yet and it is quite urgent for me to understand this...
Thanks in advance for all your answers!
Many is offline   Reply With Quote
Old   January 21, 2016, 07:59
Liam
Just one more thing,
What happens if porous media is present in the model? How UDF can account for the effects of this?
Elastic or Plastic Deformations in OpenFOAM NickolasPl OpenFOAM Pre-Processing 36 September 23, 2023 08:22
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 07:47
