Problem in UDF
Old   January 21, 2016, 17:06
Default Problem in UDF
cfd^2
cfd^2 is on a distinguished road
I have had a problem with a UDF. When writing
C_UDMI(c,t,0) = C_UDSI_G(c,t,0)[0];
it works perfectly, but when I write the inverse of the gradient component (or even the magnitue of the gradient) like that
C_UDMI(c,t,0) = 1/C_UDSI_G(c,t,0)[0];
I get the error:
Error: cx-set-real-entry: wta[2](float)
Error Object: 1.#inf
Could someone help me to clarify this issue?
cfd^2 is offline   Reply With Quote
Old   January 21, 2016, 17:46
`e`
`e` is on a distinguished road
The C_UDMI macro is expecting a real value (float or double depending on single or double precision). Try using a trailing dot for the numerator (makes that value a real number instead of an integer):
C_UDMI(c,t,0) = 1./C_UDSI_G(c,t,0)[0];
`e` is offline   Reply With Quote
Old   January 21, 2016, 18:26
cfd^2
Thank you. But didn't work... Any other tip?
Old   January 21, 2016, 19:50
`e`
Then it's probably another line at fault (unless C_UDSI_G(c,t,0)[0] is returning zero in at least one of the cells; which might explain your error of "1.#inf"). Try only using that line within the UDF and add in a Message(); function to output the value of C_UDSI_G(c,t,0)[0] and 1./C_UDSI_G(c,t,0)[0]; to the command line. You may want to perform this debugging on a mesh with fewer cells to avoid excess messages being printed to the screen.
If you find that there are cells with zero gradient values (generally the case for the first iteration, regardless) then you could add a conditional statement to avoid the error:
if (C_UDSI_G(c,t,0)[0] == 0.)
    // gradient is zero, don't try to divide by zero!
else
    // gradient is nonzero, now you can divide
Old   January 21, 2016, 19:53
cfd^2
I got it! I was interpreting the UDF. I compiled it and it worked using you tip (./)! Thank you very much!
fluent, udf
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 08:51
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 15:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 10:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
