cg motion-udf-dynamic mesh
Old   February 27, 2012, 16:15
Default cg motion-udf-dynamic mesh
amir
omidvar is on a distinguished road
I wrote a simple UDF code for describing pitching motion of a
projectile as below:
#include"udf.h"
DEFINE_CG_MOTION(pitching,dt,vel,omega,time,dtime)
omega[2]=20.0*cos(10.0*time*3.1416/180.0);
But when I wanted to create dynamic mesh zone, Fluent reports:
"Warning: incorrect cg motion UDF pitching on zone 10 (assuming no motion)"
I confused, I searched udf manual and cfd online forums but I couldn't
find the reason of problem.
If someone know the solution please help me.
omidvar is offline   Reply With Quote
Old   March 11, 2012, 03:50
Spring.s is on a distinguished road
Hi dear Amir
I think that the using udf for your case, is very short!
Too, i think that You must define Thered in udf.
Spring.s is offline   Reply With Quote
Old   March 12, 2012, 13:51
amir
Originally Posted by Spring.s View Post
Hi dear Amir
Hi dear Spring
Whould you please explain more?
what is Thered in udf?
Old   March 13, 2012, 23:21
Hi
There is one example in UDF manual about one directional motion that use Thread for define moving wall in fluent
Old   March 26, 2013, 02:03
Paritosh Vasava
vasava will become famous soon enough
I think that you must have something else in your UDF that describes the motion/position of other faces/boundaries in your domain. While you have moving/dynamic face/boundary the motion of mesh attached to this face affects the meshes attached to other faces/boundaries.
I suggest you have a close look at the tutorial titled 'Using a UDF to Control the Dynamic Mesh of a Flexible Oscillating Membrane'.
vasava is offline   Reply With Quote
Old   June 7, 2013, 03:10
Nitish Singh
nitman118 is on a distinguished road
Send a message via Yahoo to nitman118
hey vasava could you provide us with the tutorial or maybe point us out where its located....thanx
nitman118 is offline   Reply With Quote
Old   June 7, 2013, 03:38
Nitish Singh
hey vasava could you please send me the tutorial on : nitman118@yahoo.com....will be a great help....thanks
Old   July 14, 2013, 01:47
Poria honarmand
poriaFoam is on a distinguished road
Send a message via Yahoo to poriaFoam
Hi Mr omidvar
I had same problem like you, and i found it depends on your fluent version, i guess you use fluent x64, if you use from x86/x32 it will solve.
poriaFoam is offline   Reply With Quote
Old   February 21, 2016, 00:17
arshia
hamed1987 is on a distinguished road
hi omidvar,
if you describe your case ,
maybe i could help you,
what is your case and what do you want ???
what is your mesh zone setup??
i think you have a problem in dynamic mesh setup
hamed1987 is offline   Reply With Quote
Grid motion with UDF fivos Fluent UDF and Scheme Programming 5 June 30, 2018 08:50
Dynamic Mesh UDF Jkl FLUENT 9 September 6, 2011 23:43
Dynamic mesh udf example avant FLUENT 2 September 16, 2005 01:24
UDF, dynamic mesh motion phil FLUENT 0 September 15, 2004 05:42
Problem related with UDF for dynamic mesh Ryan FLUENT 6 April 29, 2004 09:29
