UDF Outputs dont match exactly for volumetric heat generation.
Old   December 31, 2015, 10:19
Default UDF Outputs dont match exactly for volumetric heat generation.
nm
nvarma is on a distinguished road
I checked and crosschecked and backcalculated and everything.
I have a volumetric heat generation rate set as a function of coordinates. If I manually calculate the numbers (which I have set in the udf) I get say 10kW exact. But when it comes to udf, the total volume integral is only 9500W.
The contour plot makes sense. Heat balance is exact. But the 500W difference?
Anybody?
nvarma is offline   Reply With Quote
Old   January 2, 2016, 17:38
`e`
`e` is on a distinguished road
Are you calculating heat generation at the nodes or cell centres? What is the UDF you are using to calculate the volume integral?
`e` is offline   Reply With Quote
Old   May 23, 2016, 08:55
nm
Based on cell centres.
I have come to the conclusive assumption that this is the discretization error from the mesh?
Old   May 23, 2016, 17:41
`e`
The mesh would need to be quite coarse to be missing 5 % of the heat generation (try mesh refinement). What is the UDF you are using, are you sure it's calculating across the full volume?
fluent 14.5.7
Define_profile UDF for Transient Heat flux boundary condition Amoljoshi Fluent UDF and Scheme Programming 2 June 20, 2018 21:55
variable Heat Source for Solid Region with UDF Alex90 Fluent UDF and Scheme Programming 3 February 24, 2015 11:24
use of pointers in specific heat udf mdakbari Fluent UDF and Scheme Programming 0 April 18, 2014 11:37
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
heat source UDF error co2 FLUENT 8 May 18, 2004 07:47
