UDF profile based on function of flow time ERROR!
Old   September 1, 2016, 18:39
Default UDF profile based on function of flow time ERROR!
Ash Kotwal
Ash Kot is on a distinguished road
I'm running 2 phase flow implicit Eularian-Eularian flow model.
created model.
defined material to each phase.
defined boundary conditions-for inlet, it's mass flow rate with initial gauge pressure defined
defined outlet pressure boundary condition- as outlet pressure values.
Then velocity slip ratio defined based on variable mass flow rate of phase 1 but constant mass flow rate of phase 2.
All above boundary conditions are defined as profile UDFs as function of flow time.
then phase coupled simple solver is used.
rest is just a calculations activities, with surface monitors.
the case successfully setup and started calculations till 300 time steps with 1 second as time step size.
after that UDF, as function of time, provides new values to the solver. and that's where everything goes wrong and suddenly I receive divergence in AMG solver. Which I shouldn't be getting since the case ran successfully for first 300 time steps
so I need help to know what exactly went wrong.
thank you,
regards,
Ash Kot is offline   Reply With Quote
Old   September 2, 2016, 09:35
Bruno Machado
Bruno Machado is on a distinguished road
created model.
thank you,
regards,
We have no idea about your code or if something else in your configuration is wrong. Maybe the time step you are using is too big, maybe is under relaxation factor, maybe is something else. with the information you provide, i dont think any one can help you.
Bruno Machado is offline   Reply With Quote
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 11:04
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 18:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
