Fluent automatically switched to parallel mode
Old   November 5, 2019, 00:48
Default Fluent automatically switched to parallel mode
Rahul
rahulmule797@gmail.com is on a distinguished road
Hello everyone, I am starting fluent in serial mode but it is getting started in parallel mode. I don't know why this is happening so the udf I am using in my problem is not doing the intended function. Any immediate help is appreciated. I'm also shared the warning is shows on fluent launch.
Info: Your license enables 4 way parallel execution.
For faster simulations, please start the application with the appropriate parallel options.
When I'm trying to interpret the UDF it is showing warning as below:
**WARNING:Automatically switched to run in parallel -t1 mode. **
**Detected non- Paralleized UDF usage, enabling parallel usage. **
**If you encounter any issues, please re-run with -t0 flag. **
Thanks in advance..
rahulmule797@gmail.com is offline   Reply With Quote
Old   November 5, 2019, 03:34
gearboy is on a distinguished road
Reduce the "Processes" to "0" in launcher or Start fluent using "fluent 3d -t0" in cmd.exe console
Thanks in advance..
gearboy is offline   Reply With Quote
Old   November 5, 2019, 03:38
Rahul
Thanks for reply..
I tried by reducing processes to zero but in that case udf is not doing intended function.
I'll check it by starting using "fluent 3d -t0" In cmd.exe in console.
Floating point exception during parallel mode of fluent aamer FLUENT 10 May 16, 2019 09:49
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 18:58
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Problem with Parallel Fluent mohamed_ FLUENT 1 December 28, 2012 11:23
