Dpm udf
Like Tree1Likes
  • 1 Post By pakk
Old   February 16, 2017, 10:57
Default Dpm udf
SinaJ
sina_mech is on a distinguished road
I would like to set flow rate for an injection of particles. The injection is a surface injection. Over the loop, I set P_FLOW_RATE(p), but I noticed that the flow rate applies to every stream in that injection. So for example, for a surface injection (of say 100 streams at inlet), instead of having 1 kg/s , I have 100kg/s eventually! any fix? I would like to have 1kg/s for the entire injection, also "Scale flow rate by face area".
This is a sample code that I use:
#include "udf.h"
DEFINE_DPM_INJECTION_INIT(init_prt,  I)
	Particle *p;
	real t = CURRENT_TIME;
	if (t>=0)
		loop(p,I->p_init)
			P_FLOW_RATE(p) = 1.0;
sina_mech is offline   Reply With Quote
Old   February 16, 2017, 11:32
pakk will become famous soon enough
P_FLOW_RATE(p) defines the flow rate for trajectory p. If you want to distribute 1 kg/s over 100 different trajectories, you will have to do that yourself!
If you know that there are exactly 100, and you want to distribute them equally over the trajectories, the simplest way is to do the calculation yourself and conclude you need 0.01 kg/s for each trajectory:
P_FLOW_RATE(p) = 0.01;
If you want to make it proportional to the face area, you have to:
1. Find out which on which face the particle is.
2. Calculate the area of that face.
3. Put that area in the equation.
I will put some thoughts on these 3 steps below.
1. Find out which on which face the particle is:
I don't know how to find the face, but to find the cell, you do:
cell=P_CELL(p);
cell_thread=P_CELL_THREAD
Maybe P_FACE(p) also works...
2. Calculate the area of that face:
If you know it is on face "face" on face thread "face_thread":
F_AREA(A,face,face_thread);
facearea=NV_MAG(A);
You need to know the total flow rate that you want to have (1kg/s in your case), and the total area of the surface. Either you read that one from Fluent, or you use a UDF to calculate that. Then, the relevant part becomes:
P_FLOW_RATE(p) = facearea/totalarea*totalflowrate;
sina_mech likes this.
Last edited by pakk; February 17, 2017 at 03:50. Reason: minor textual improvements
pakk is offline   Reply With Quote
Old   February 19, 2017, 16:26
SinaJ
cell=P_CELL(p);
facearea=NV_MAG(A);
pakk, thank you very much. I will try this.
WILLING TO PAY/ FREELANCER REQUIRED / small UDF coding force loads over body / 6DOF acasas CFD Freelancers 1 January 23, 2015 07:26
Add Mass to a Particle with UDF (DPM) sega Fluent UDF and Scheme Programming 6 October 24, 2013 22:14
please help me. i have question about the UDF at the DPM motallebi FLUENT 0 July 6, 2009 11:27
Velocity of Fluid @ different positions of Particle in DPM using UDF pmghadge FLUENT 1 June 16, 2009 19:11
UDF DPM injection M.A. Rakib FLUENT 0 June 13, 2000 08:28
