Cell number from UDF
Old   March 21, 2017, 10:21
Default Cell number from UDF
Rakesh
rsarma is on a distinguished road
I am writing a parallel UDF code for a deforming mesh problem. Basically I want to update the cells of a boundary at every time step. This update is based on a matrix which I read into my code. Each element of this matrix corresponds to a cell centre in the boundary that needs to be updated.
My problem is since the mesh is updating at each time step, it's coordinates change. As such, I cannot identify the cells and read the matrix values for a particular cell.
I was wondering if it possible to write the cell ID to a file? Or could you kindly give me any other suggestions?
Best,
R
rsarma is offline   Reply With Quote
Old   March 23, 2017, 08:33
KirMaks
kirmaks is on a distinguished road
Hallo,
I've recently thought about similar problem. You may use UDM to store the cell's ID and then use it to get the required element of the matrix. Several steps are required:
1. store the cell's number and its coordinates (if required) in UDM, you may also save these data in a text for analysis how to order the elements in the matrix (DEFINE_ON_DEMAND).
2. use the stored ID's from UDM to access the matrix elements during iterations.
That's it, good luck and have a nice day.
Regards, Maks
kirmaks is offline   Reply With Quote
Old   March 23, 2017, 09:00
Rakesh
Hi Maks,
Thank you for the reply. I will implement it. What is actually the macro for extracting the cell ID. I saw somewhere there is C_ID(cell_t c,Thread*t), but I am not quite sure if this exists as I could not locate it in the fluent udf manual. Could you kindly let me know?
Best,
R
Old   March 23, 2017, 09:12
KirMaks
I'm not sure, You may define Your own indexing based for example on the coordinates. May be looping is also always done in the same order. You may check it. It also states in the help that
face_t is an integer data type that identifies a particular face within a face thread.
cell_t is an integer data type that identifies a particular cell within a cell thread.
so You may check what value has the appropriate variable when You are looping throug the cells or faces.
Regards, Maks
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 12:01
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 09:42
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 08:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
