how to define a function that outputs vector instead of scalar?
Old   August 14, 2017, 12:36
Default how to define a function that outputs vector instead of scalar?
ali
alinik is on a distinguished road
Hi all,
Is it possible for us to define a function in UDF that outputs a vector (array) instead of a scalar?
I could not find an example.
Thanks,
Ali
alinik is offline   Reply With Quote
Old   August 16, 2017, 05:01
Cees Haringa
CeesH is on a distinguished road
typically, the DEFINE macro you use specifies the required output of the function. This may be a vector - for example, when using the DEFINE_VR_RATE macro the return needs to be a vector. It depends on the sort of data FLUENT is expecting.
Of course, within the UDF itself, you can use all the arrays you want.
CeesH is offline   Reply With Quote
Old   August 16, 2017, 09:47
ali
Thank you Cees for your reply.
Can I use DEFINE macro to define a vector field?
For example whenever we want to define a scalar function, we use somthing like this:
real func1(cell_t c, Threat *t){
Is there something similar to this for defining vector functions?
Thanks,
Ali
Old   August 17, 2017, 05:09
Cees Haringa
Maybe this helps?
https://www.tutorialspoint.com/cprog...m_function.htm
array, function, scalar, udf, vector
access to member function variable Rahand OpenFOAM Programming & Development 3 March 29, 2016 15:46
solving passive scalar by user function in AVLFIRE huyp Main CFD Forum 0 September 4, 2008 10:21
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 06:27
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
