Thermoelectric UDF running problem. Error 193 |
September 27, 2017, 08:56 |
#1 | |
Pablo Mtz. Filgueira
Rep Power: 12 |
Hello everyone.
I'm trying to run a simulation where an UDF is involved and I can't make it run. I attach the files in this LINK It includes the .cas file and a library .dll. They come from a paper https://doi.org/10.1016/j.ijheatmass...er.2010.08.024 where a thermoelectric UDF is developed within ANSYS Fluent. In the appendix says that it contains the required files to work in Fluent 12 directly. I create my case and place the library in C:\Users\pxxxxxxxx\Documents\TEG\libudf\win64\3d , which I think is the right place. I have also tried with no success placing it into the root of the case. I've been prompted in this error every time I start this simulation. Code:
Opening library "C:\Users\pxxxxxxxx\Documents\TEG\libudf"... Error: Error code: 193 Error: Error code: 193\n Error Object: #f I would like, first of all, someone to test that file to know if it works. It is cool stuff so I think you will enjoy trying it I'm running on Visual Studio Express 2015 and launch Fluent from VS2015 x86 x64 Cross Tools Command Prompt. I can run and build all the tutorials so I think my compilation environment is OK. My PC is Windows 10 Pro 64bits. My Fluent version is 17.1. Any suggestion or test will be welcomed. Thank you. Quote:
March 9, 2018, 09:36 |
#2 | |
Inderjeet Singh
Rep Power: 9 |
Can you please explain how did you overcome that problem.. ? I have similar error ... In the end you mentioned "32 bit system was the key". Did you converted it or something else ? |
March 15, 2018, 03:59 |
Rep Power: 12 |
193, error, fluent, thermoelectric, udf |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Problem running fluent with udf on supercomputer(batch system) | Sept24 | Fluent UDF and Scheme Programming | 3 | October 15, 2015 12:50 |
Wankel Engine UDF Problem | Kxt908 | Fluent UDF and Scheme Programming | 0 | February 2, 2014 08:15 |
UDF Problem about Grid Motion !!! | Zhengyu Gao | Fluent UDF and Scheme Programming | 0 | December 6, 2013 19:45 |
Mesh UDF problem | kornetka | Fluent UDF and Scheme Programming | 4 | July 25, 2013 06:54 |
