How do I set a turbulent prandtl number(for example 4.22 instead of the default 0.85,
Like Tree1Likes
  • 1 Post By IET
Old   June 6, 2015, 21:44
Default How do I set a turbulent prandtl number(for example 4.22 instead of the default 0.85,
IET
yunhaifeiyang
IET is on a distinguished road
Dear experts:
In Fluent, the default turbulent prandtl is 0.85 for conventional fluid (air and water et al.), but for heavy metal (lead bismuth eutectic et al.), its turbulent prandtl is larger than 1.0. So I want to set it 4.22 instead of 0.85. But I don't know how to do it? Use UDF?
For standard k-epsilon et al, we can use UDF to change the parameters (as shown in fig. 1). Once you start using UDF, Fluent is at your command.
But if I used is Large Eddy Simulation, not in standard k-epsilon, and there is no TKE Prandtl number. There are Energy Prandtl number and Wall Prandtl number(as shown in fig. 2). In user guide, they are the turbulent Prandtl number for energy and the turbulent Prandtl number at the wall, and the default is 0.85 respectively. If I want to set it 4.22 instead of 0.85, Which one should I modify? If I want to use UDF, How should I do?
Please help me!
nishidd likes this.
IET is offline   Reply With Quote
Old   March 8, 2021, 13:57
Gaurav Kumar
gauravkmr is on a distinguished road
Facing the same problem.
gauravkmr is offline   Reply With Quote
fluent, turbulent prandtl, udf
what is the 'Wall Turbulent Prandtl Number'? begginer FLUENT 2 October 1, 2013 22:42
How to set the inflow conditions of turbulent BL? CFDer Main CFD Forum 2 March 8, 2006 09:05
Can Turbulent Prandtl Number > 1.5? GER Main CFD Forum 4 December 14, 2004 23:31
Turbulent Prandtl Number Ron CFX 1 November 2, 2003 08:32
Prandtl Mixing length Vs. Isotropic turbulent Mohammad Kermani Main CFD Forum 0 March 23, 2000 23:06
