Writing DO intensity into file with parallel architecture using UDF
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   December 16, 2022, 04:59
Default Writing DO intensity into file with parallel architecture using UDF
Kuljeet Singh
Kuljeet is on a distinguished road
hi
i am using this UDF to write DO intensity into a file. the case is square cavity with wall at 0K and CO2 at 1000K inside). When i am writing for individual face, i am getting right values its not happening for the whole wall, i am using a coarse grid just to check that. can anyone look into it. I think the problem is with parallel architecture i.e., have 1 host and 1 node process.
-K
Link for case file, UDF and generated files for both case.
"https://drive.google.com/file/d/1dItCD05Y9APaoA-AWt6RsqSvFhg5YUMd/view?usp=share_link"
Kuljeet is offline   Reply With Quote
Old   December 16, 2022, 07:20
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
share your code, explain problems
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   December 17, 2022, 04:40
Default UDF to write Intensity. i have shared with above google drive link.
Kuljeet Singh
#include "udf.h"
# define FLUID_ID 2
DEFINE_ON_DEMAND(intensity_to_file)
/* Different variables are needed on different nodes */
#if !RP_HOST
Domain *domain=Get_Domain(1);
Thread *thread;
face_t f;
cell_t c;
int k;
#else
int i;
#endif
#if !RP_NODE
FILE *fp = NULL;
char filename[]="intensity12.txt";
#endif
int size; /* data passing variables */
real *array;
int pe;
#if !RP_HOST
thread=Lookup_Thread(domain,8); // bottom wall id =8;
#endif
#if !RP_NODE
if ((fp = fopen(filename, "w"))==NULL)
Message("\n Warning: Unable to open %s for writing\n",filename);
else
Message("\nWriting intensity to %s...",filename);
#endif
/* UDF Now does 2 different things depending on NODE or HOST */
#if RP_NODE
/* Each Node loads up its data passing array */
size=THREAD_N_ELEMENTS_INT(thread)*4*1*1;
array = (real *)malloc(size * sizeof(real));
//for (int l=0;l<10;l++)/////////////////////////////////writing
begin_f_loop_int(f,thread) //f is from 0 to 9
for(k=0;k<4;k++) ////////////k is no of angualr discritised grid points = phi*theta*4(2D case)
array[k*(l+1)]= C_DO_I(l,thread,k);
Message("%f\n",array[k*(l+1)]);
//printf("%lf",array[k]);
//array[k]= F_DO_I(9,thread,k);
end_f_loop_int(f,thread)
/* Set pe to destination node */
/* If on node_0 send data to host */
/* Else send to node_0 because */
/* compute nodes connect to node_0 & node_0 to host */
pe = (I_AM_NODE_ZERO_P) ? node_host : node_zero;
PRF_CSEND_INT(pe, &size, 1, myid);
PRF_CSEND_REAL(pe, array, size, myid);
free(array);/* free array on nodes after data sent */
/* node_0 now collect data sent by other compute nodes */
/* and sends it straight on to the host */
if (I_AM_NODE_ZERO_P)
compute_node_loop_not_zero (pe)
PRF_CRECV_INT(pe, &size, 1, pe);
PRF_CRECV_REAL(pe, array, size, pe);
PRF_CSEND_INT(node_host, &size, 1, myid);
PRF_CSEND_REAL(node_host, array, size, myid);
free((char *)array);
#endif /* RP_NODE */
#if RP_HOST
compute_node_loop (pe) /* only acts as a counter in this loop */
/* Receive data sent by each node and write it out to the file */
PRF_CRECV_INT(node_zero, &size, 1, node_zero);
PRF_CRECV_REAL(node_zero, array, size, node_zero);
//for (i=0; i<8; i++)
for (i=0; i<size; i++)
fprintf(fp, "%g\n", array[i]);
free(array);
#endif /* RP_HOST */
#if !RP_NODE
fclose(fp);
Message("Done\n");
#endif
Old   December 26, 2022, 03:06
Alexander
try this code, compile
#include "udf.h"
# define FLUID_ID 2
Domain *domain;
Thread *thread;
face_t f;
cell_t c;
int i,k;
FILE *fp = NULL;
real *array;
#if !RP_NODE
else
#endif
#if RP_NODE
begin_f_loop_int(f,thread) /*f is from 0 to 9*/
	for(k=0;k<4;k++) /*k is no of angualr discritised grid points = phi*theta*4(2D case)*/
	array[k*(f+1)]= C_DO_I(f,thread,k);
	Message0("%f\n",array[k*(f+1)]);
#endif
node_to_host_int_1(size);
node_to_host_real(array,size);
#if !RP_NODE
free(array);
fclose(fp);
#endif
Message0("Done\n");
Kuljeet likes this.
best regards
Old   December 26, 2022, 03:42
Default showing error
Kuljeet Singh
Thanks for replying, but this code is not compiling. It is showing error mentioned below. I think we cant write to a file without using parallel architect.
ERROR: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
The system cannot find the file specified
-K
Old   December 26, 2022, 05:02
Alexander
press build, not load
best regards
Old   December 26, 2022, 05:07
Kuljeet Singh
But how will i execute it. If i just load code, it is not showing in "execute on demand". So its not writing into anything.
Old   December 27, 2022, 02:07
Alexander
google "how to compile code in fluent"
best regards
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
OpenFoam "Permission denied" and "command not found" problems. iyidaniel@yahoo.co.uk OpenFOAM Running, Solving & CFD 11 January 2, 2018 06:47
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
