RP_Get_List_Ref_Real exists?
Old   May 4, 2018, 11:12
Default RP_Get_List_Ref_Real exists?
DS
denis.sanga@hotmail.it is on a distinguished road
Goodmorning,
I'm writing an UDF where I need to read and modify the value store in a rp real list created as follow:
(make-new-rpvar 'average_list '() 'real-list)
(rpsetvar 'average_list ())
(rpsetvar 'average_list (list-add(rpgetvar 'average_list) 1.1))
(rpsetvar 'average_list (list-add(rpgetvar 'average_list) 2.2))
(rpsetvar 'average_list (list-add(rpgetvar 'average_list) 3.3))
(rpgetvar 'average_list )
I tried to use
RP_Get_List_Ref_Real("average_list",0)
and
RP_Set_List_Ref_Real("average_list",0)
, but doesn't work.
Can someone help me to solve this problem?
Thank you really much
Best regards
Denis
denis.sanga@hotmail.it is offline   Reply With Quote
Old   May 5, 2018, 18:40
obscureed is on a distinguished road
Hi Denis,
Please could you post the UDF code that does not work?
We know from the Fluent header file var.h that the function you mentioned should exist -- here it is (unless it has changed in recent versions):
FLUENT_EXPORT double RP_Get_List_Ref_Float(char *s, int n);
While we're in var.h, here are some useful functions:
FLUENT_EXPORT cxboolean RP_Variable_Exists_P(char *s);
FLUENT_EXPORT int RP_Get_List_Length(char *s);
FLUENT_EXPORT void RP_Set_List_of_Float(char *s, double *a, int length);
So I'm expecting something like:
#include "udf.h"
DEFINE_ON_DEMAND(read0)
  double value0;
  value0 = RP_Get_List_Ref_Float("average_list",0);
  Message0("value0 from average_list = %16.8g\n",value0);
DEFINE_ON_DEMAND(set4)
  double my_array[] = {0.,111.,222.,333.};
  int len_my_array;
  len_my_array = sizeof(my_array)/sizeof(my_array[0]);
  RP_Set_List_of_Float("average_list",my_array,len_my_array);
Sorry, I've written this without checking that it works.
Good luck!
Ed
obscureed is offline   Reply With Quote
rp_get_list_ref_real
Cell_Function_Values: No post-processing value exists. jypark FLUENT 4 November 18, 2020 02:40
Cell_Function_Values: No post-processing value exists lixinjun Main CFD Forum 0 December 13, 2016 22:44
The CFX Setup case file no longer exists. Continuing in an initial state. ced30 CFX 1 November 13, 2015 12:00
[GAMBIT] ERROR: The key, 0XAF8A, already exists in this HashTool fluent-user ANSYS Meshing & Geometry 2 February 11, 2013 19:17
exists minimum grid size for Ansys calculation? sooh2121 ANSYS 2 March 7, 2012 10:34
