UDF - problem
Old   October 26, 2018, 04:43
Default UDF - problem
Krzysztof
roger87 is on a distinguished road
. I have the problem with one numerical approach presented on the website (fluent documentation), that the link is below. Please, explain me how to implement this approach. I prepared two files as it is written on the website. My error is: there is no the file extfile.h Even I tried to prepared the third file extfile.h which contains only the text “extern real volume” and I tried to attached this file in Fluent but without success. What do I wrong?
https://www.sharcnet.ca/Software/Flu...df/node243.htm
Best regards
roger87 is offline   Reply With Quote
Old   October 26, 2018, 21:42
blackmask will become famous soon enough
When you add source files, set the filter to "all file types" instead of "source files (.c, .cpp)".
blackmask is offline   Reply With Quote
Old   October 27, 2018, 03:05
Krzysztof
OK, thank you
udf error
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
Problem with DPM simulation with particles injection and EXECUTE_AT_THE_END UDF. Ari Fluent UDF and Scheme Programming 4 May 31, 2016 08:51
udf loading problem santu Fluent UDF and Scheme Programming 1 May 22, 2015 15:47
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 10:59
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
