Save & read a vector (array) in same or other macros for next time step or iteration
Old   February 28, 2019, 12:43
Default Save & read a vector (array) in same or other macros for next time step or iteration
Peter Maroul
Pmaroul is on a distinguished road
Hello all;
How can we save a written vector(array) (for example 2*30 ) and read (use) it for other or same UDF macros in the next time step or iterations?
Thanks a lot for any advice.
P.Maroul
Pmaroul is offline   Reply With Quote
Old   March 3, 2019, 17:55
Peter Maroul
Maybe I couldn't ask my question clearly, therefore I try to re-raise my question with a Pseudocode .
#include udf.h
for(int i=0;i<n0;i++)
for(int j=0;j<m0;j++)
A(i,j)= A(i,j)+ /*some modifications or updates*/
DEFINE_ADJUST(my_adjust,d)
/*some written text codes*/
Is the updating of this array(A(i,j) ) possible or this quantity re-initialized to zero in every iteration?
Old   March 3, 2019, 20:38
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
#include udf.h
int n,m,i;
real **A;
A= (real**)malloc((m)*sizeof(real*));
for (i=0; i<m; i++)
			A[i] = (real*)malloc(n*sizeof(real));
you may use this array everywhere and update whenever you want
best regards
AlexanderZ is offline   Reply With Quote
Old   March 4, 2019, 05:15
Peter Maroul
Originally Posted by AlexanderZ View Post
#include udf.h
int n,m,i;
real **A;
for (i=0; i<m; i++)
best regards
Thanks sir so much.
How about two-dimensional arrays?
Is the following Pseudocode right?
#include udf.h
int n,m,i;
real **A;
for (j=0; j<m; j++)
for (i=0; i<n; i++)
			A[i][j] = (real*)malloc(n*sizeof(real));
Moreover, is the file printing a good idea(For example , rewriting a new matrix in the file and its reading for the next iteration ) specially if matrix (array) post-processing is to be important for us in any time step?
Old   March 4, 2019, 05:27
pakk will become famous soon enough
No, your code is not correct.
See for example here how to correctly allocate a 2D array in c.
pakk is offline   Reply With Quote
Old   March 4, 2019, 20:48
Alexander
I gave you code for memory allocation for 2D array (matrix)
than you may define value of each element in matrix using 2 loops for i and j
you may do whatever you want. but reading/writing to file may take some time, depends on the size of your matrix. play with it.
reading/writing to file functions are different for single core computation and parallel approach, take it into account
best regards
Old   March 5, 2019, 15:27
Peter Maroul
Thanks Sirs very much !
If you're not in a hurry, can you send a Pseudocode executing the matrix's printing(A[i,j]) in a file, for example, in intervals of every ten time steps, and then from which part of the FLUENT options, the output of this matrix is visible?
for example for a 2D array , how can I plot A[i][1] versus A[i][2] in each 10 deltaT in Fluent or other post processing tools?
Thanks in advance for any help.
Old   March 21, 2019, 10:10
Peter Maroul
best regards
Dear Alexander.
Are the n, m constant parameters dynamic allocated in udf's , too?
Old   March 22, 2019, 06:18
Peter Maroul
#include udf.h
int n,m,i;
real **A;
A= (real**)malloc((m)*sizeof(real*));  /*command line4*/
for (i=0; i<m; i++)
best regards
Dear Alexander
I compiled your suggested sub-code and encountered below error:
error C2040: 'A' : 'int ' differs in levels of indirection from 'double ** ' for the command line 4:"A= (real**)malloc((m)*sizeof(real*));"
How can I resolve this error?
Old   March 25, 2019, 00:27
Alexander
#include "udf.h"
int n = 10,m =10;
real **A;
DEFINE_ON_DEMAND(Allocate_memory)
int i,j;
for (i=0; i<m; i++)
DEFINE_ON_DEMAND(Define_matrix)
	int i,j;
	for (j=0; j<m; j++)
	{	for (i=0; i<n; i++)
			A[i][j] = i+j;
DEFINE_ON_DEMAND(Free_memory)
	free(A);
best regards
Old   March 30, 2019, 06:05
Peter Maroul
Dear Alexander.
Your answer was so helpful!!. Really I had to define that array in a define-on-demand and then to update in other macros.
Good luck and best wish for you.
next time step, read array, save array
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
Kernel for new CPUs Simbelmynė Hardware 22 January 5, 2018 16:41
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 13:40
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
