October 8, 2019, 03:27 |
UDF for mass flow
Västerbotten
Rep Power: 9 |
Hi!
I'm trying to write a udf where the mass flux of the secondary phase at the face with id=7 is used as the mass flux in the boundary where I use the udf. DEFINE_PROFILE(inlet_mass_flow,t,i) { real mass_in = 0; real mass_tot = 138.30072; int phase_domain_index = 1; /* secondary phase index is 1 */ Domain *mixture_domain; Domain *subdomain = DOMAIN_SUB_DOMAIN(mixture_domain,phase_domain_inde x); Thread *mixture_thread; /* mixture-level thread pointer */ Thread *subthread = THREAD_SUB_THREAD(mixture_thread,phase_domain_inde x); face_t f; subthread = Lookup_Thread(subdomain, 7); mass_in = F_FLUX(f,subthread); mass_tot = mass_in; mass_in = 0; begin_f_loop(f,t) { F_PROFILE(f,t,i) = mass_tot; } end_f_loop(f,t) } This lead to an immediate crash when I click ok. Can anyone give me some pointers? Last edited by Per_Holmgren; October 8, 2019 at 05:48. |
October 10, 2019, 13:50 |
Västerbotten
Rep Power: 9 |
In case anyone else comes across this post, I figure I might as well post the code I came up with to solve my problem.
In my case CaCO3 enters a reactor, converts to CaO and CO2, and CaO and CaCO3 leaves at the outlet at a set volume per second (specified as a negative velocity profile in a different udf). Based on the mass flow of solids out, and the degree of conversion, I need to refill the reactor with an equal amount of CaCO3 to match the amount of CaCO3 and CaO that leaves at the solids outlet. DEFINE_PROFILE(adjust_inlet, t, i) { face_t f; real massflow=0; real massflow_tot=130; real massfraction_CaCO3=0; Domain *d; Domain *d_sub; Thread *t_sub; d = Get_Domain(1); d_sub = DOMAIN_SUB_DOMAIN(d,1); /*Find secondary phase*/ t_sub = Lookup_Thread(d_sub, 7); /*Find thread on secondary domain with id 7*/ begin_f_loop(f,t_sub) /*Loop through all face threads on domain with id 7*/ { massflow+=F_FLUX(f,t_sub); /* Assign mass flux at given face to variable massflow for each face thread*/ massfraction_CaCO3=F_YI(f,t_sub,2); /* Find mass fraction of specie 3(CaCO3 here)to normalize massflow later*/ } end_f_loop(f,t_sub) massflow = PRF_GRSUM1(massflow); /*Sums the values of the cores into a single value*/ massfraction_CaCO3 = PRF_GRSUM1(massfraction_CaCO3); massflow_tot = (massflow*((100.09/56.08)-((100.09/56.08)-1)*massfraction_CaCO3))*2*M_PI; /*Corrects for 2D-axisymmetric profile*/ massflow=0; begin_f_loop(f,t) { F_PROFILE(f,t,i) = massflow_tot; /*Inserts flow for 2D-axisymmetric profile*/ } end_f_loop(f,t) } As I use parallel processing I need to use PRF_GRSUM1 to get my eight values of for example massflow into a single value, and to be able to compile PRF_GRSUM1 you need to start fluent from the Visual Basic command prompt. Compile Fluent UDF with Windows 10 I was stuck at the compiler issue for a pretty long time, since I didn't understand that fluent actually couldn't find the compiler. I thought my code was wrong! Last edited by Per_Holmgren; October 30, 2019 at 05:50. |
UDF to measure Mass Flow Rate | a.lynchy | Fluent UDF and Scheme Programming | 31 | October 4, 2018 14:10 |
volume flow rate for outlet boundry condition and dfine udf for it | raminostadi | FLUENT | 0 | December 24, 2016 01:52 |
UDF for 3D turbulent fully developed flow | howhs | Fluent UDF and Scheme Programming | 0 | August 1, 2013 11:47 |
UDF for time-dependent flow | borhan_sd@yahoo.com | Fluent UDF and Scheme Programming | 2 | May 30, 2013 02:59 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
