injection file for ddpm+dem
Like Tree1Likes
  • 1 Post By vinerm
Old   March 26, 2020, 11:07
Default injection file for ddpm+dem
Chanon Bunsaksit
ChanonB is on a distinguished road
Hello
I'm tying to simulate the bubbling fluidized bed using injection by file but I don't sure how to calculate the mass flowrate for each particle. Can anybody help me?
Thank you
ChanonB is offline   Reply With Quote
Old   March 26, 2020, 11:24
Default Mass Flow Rate
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Particle do not have a mass flow rate, only mass. The mass flow rate mentioned in the file is for the parcel. Simplest assumption is equal distribution. Since you know the number of parcels you want to inject and you also know the mass of one particle, mass flow rate is given by the ratio of total mass flow rate of discrete phase and product of number of parcels and mass of one particle, i.e.,
\frac{\dot{m}_{total}}{m_p\times N_p}
where N_p is number of parcels in your injection file.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 27, 2020, 05:20
vinerm's Avatar
Vinerm
Mass flow rate of particles has to come from the real system that you are trying to simulate using CFD. No one else can give you that value. Mass flow rate of each parcel has to be calculated using the procedure I shared in my previous post.
I'd recommend using forum instead of PM so that I could be corrected if I make a mistake and others could learn from whatever we are discussing.
ChanonB likes this.
Regards,
Vinerm
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 35 April 29, 2022 15:35
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
