THREAD_T0 in parallel
Old   March 27, 2016, 10:33
Default THREAD_T0 in parallel
gewuzhizhi is on a distinguished road
hi,everyone. I am now using THREAD_T0 to access the adjacent face of a interior face. while it does not work when the number of cpu over 8.does anybody know why?
gewuzhizhi is offline   Reply With Quote
Old   March 28, 2016, 09:45
the problem now is solved,it is caused by the code itself, mainly because of the message passing between node 0 and the remain nodes
Old   April 15, 2020, 02:04
Jerónimo Guarco
jeronimoguarco is on a distinguished road
Hello. Would you care to ellaborate how exactly you solved this? Thank you very much
jeronimoguarco is offline   Reply With Quote
Old   April 15, 2020, 14:59
Default Thread
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
All the functions that access anything related to mesh, such as, THREAD_T0, can only be accessed by nodes and not by host when Fluent runs in parallel. Since new versions always run in parallel, even when Serial is selected at the launcher, you need to use this and other similar functions or macros within either
#if !RP_HOST
#endif
or
#if RP_NODE
#endif
The precompiler directives ensure that there is no segmentation violation.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 04:18
Explicitly filtered LES saeedi Main CFD Forum 16 October 14, 2015 11:58
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
simpleFoam in parallel issue plucas OpenFOAM Running, Solving & CFD 3 July 17, 2013 11:30
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 16:49
