Question about using Macro F_FLUX(f,t)
Like Tree2Likes
  • 1 Post By vinerm
  • 1 Post By vinerm
Old   June 25, 2020, 03:55
Default Question about using Macro F_FLUX(f,t)
Kaazem
Kaazem_RA is on a distinguished road
Hello everybody,
I want to implement an equation (governing equation of flow in porous media) which is very similar to Navier-Stokes equation, in ansys fluent. I have attached a photo of the equation. As can be seen from the photo i need to change the convective term. In fact the convective term is multiplied by a constant (1/phi^2 phi is porosity). I think the appropriate macro is F_FLUX(f,t) and i also wrote UDF to do that however after compiling the UDF i receive fatal signal (segmentation fault). Below is the UDF i have developed. It would be highly appreciate if anyone helps me to fix this problem.
#include "udf.h"
#include "mem.h"
#include "math.h"
DEFINE_ADJUST(set_convective_flux, d)
real porosity = 0.95;
Thread *t;
cell_t c;
face_t f;
thread_loop_c(t,d)
begin_c_loop(c,t)
thread_loop_f(t,d)
begin_f_loop(f,t)
F_FLUX(f,t) = F_FLUX(f,t)/(porosity*porosity);
end_f_loop(t, d)
end_c_loop(c,t)
Kaazem_RA is offline   Reply With Quote
Old   June 25, 2020, 04:06
Default Loop
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
That's because you are using two loops. You don't need two outermost loops. Just thread_loop_f and begin_f_loop.
However, there are other problems with the code. You can looping over all the boundaries, while F_FLUX exists only for openings, such as, inlet, outlet, etc.
Kaazem_RA likes this.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 25, 2020, 05:21
Kaazem
Thank you very much for your reply. I removed the outermost loops in the code and i successfully ran the simulation. You said that "F_FLUX(f,t) exists only for openings". It means that i do not correctly implement the equation. right? I think there is no other macro that returns convective flux through all faces (internal and external). Do you have any suggestion on implementing the equation?
Old   June 25, 2020, 05:54
Default F_flux
vinerm's Avatar
Vinerm
The function exists irrespective of the condition. What I meant is that the fluxes will have a non-zero value only for the openings. Of course, you wouldn't expect fluxes for the walls or symmetry. Periodic conditions on the other hand will have fluxes and so does the interior. But, it would still be better to call this function only on openings.
Regards,
Vinerm
Old   June 25, 2020, 11:03
Kaazem
You're right. The fluxes will have a non-zero value only for the openings but i think convective flux of each internal face is not zero. That's why i loop over all faces(internal and external) to change convective flux to implement the equation. I guess this is the only way to manipulate convective terms of Navier-Stokes equations in ansys fluent.
Macro Heat Exchanger not selecting (Please help!) zdeth FLUENT 2 September 11, 2012 13:52
Run macro for Multiple file furione STAR-CCM+ 6 November 28, 2011 14:54
Macro Problem!!! eRzBeNgEl STAR-CCM+ 3 August 9, 2011 02:04
Movie Macro in Tecplot TedBrogan Tecplot 2 February 4, 2011 10:59
Macro problem cfddummy Siemens 1 April 9, 2007 12:37
