Defining mass flow rate as an input parameter in Fluent |
July 16, 2020, 21:03 |
Dinis Nunes
Rep Power: 6 |
Greetings,
I have a simulation with a transactional periodic boundary, and I want to vary the mass flow rate to test different cases. I'm able to define regular inputs and output as parameters, as well as variables used in a UDF I'm employing. However, I can't seem to find how to do this for the values in the Periodic Conditions tab (where the mass flow rate is located and defined). Any help in how to solve this would be greatly appreciated. Dinis Nunes |
July 17, 2020, 00:40 |
Alexander
Rep Power: 34 |
whats your work flow, how do yu apply value for mass flow?
is it correct, that you are using parameter value from workbench? Or you are using UDF boundary condition?
best regards ****************************** press LIKE if this message was helpful |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
DPM total mass flow rate | yow | FLUENT | 0 | July 17, 2015 12:01 |
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 21:11 |
mass flow rate computation in fluent | Kishore | FLUENT | 5 | June 27, 2007 03:53 |
particle, parcel and mass flow rate balance | flybird | FLUENT | 0 | May 24, 2007 10:44 |
