udf initialization problem
Like Tree1Likes
  • 1 Post By pakk
Old   March 2, 2021, 17:39
Default udf initialization problem
reza
rezaaa2 is on a distinguished road
hi. i recently started to learn udf and want to use slip boundary condition(navier slip) in my project so i write a udf and compile it in fluent successfully. but when i initialization it encounter with this message:
Error: received a fatal signal (Segmentation fault)./Error Object: #f/
i found that this error occur when use velocity (C_U(cell,c_thread))or velocity gradient (C_U_G(cell,c_thread)[1]) in my udf and in other cases initialization is succesfull But I didn't understand where is problem ?
rezaaa2 is offline   Reply With Quote
Old   March 3, 2021, 00:41
pakk will become famous soon enough
When you initialize, the data does not exist yet. If your UDF does a calculation with velocity, but velocity does not exist yet, you get this warning.
Solution : initialize without the UDF, and then activate it.
And I hope you know that first order velocity slip is implemented in Fluent, you don't need a UDF, just use low-pressure boundary slip...
amirmehrabi likes this.
pakk is offline   Reply With Quote
initialization method, navier slip, slip wall, udf compile
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 06:05
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 00:53
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 10:59
problem of udf with material property france Fluent UDF and Scheme Programming 2 May 27, 2014 08:08
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
