Validating heat flux profile
Old   August 31, 2021, 12:50
Default Validating heat flux profile
YADU KRISHNAN N
Yadu krishnan is on a distinguished road
I have used following UDF for neumann boundary condition as heat flux profile. How can I validate if it is working fine?
#include "udf.h"
DEFINE_PROFILE(Heat_flux,thread,position)
Thread *t;
Thread *tf;
cell_t c;
face_t f;
real x[ND_ND];
real cell[ND_ND];
int n;
int k = 1;
real wf;
real nc;
real temp;
real tempgrad ;
real Twall=100;
real delta;
begin_c_loop_all(c,t)
c_face_loop(c,t,n)
tf = C_FACE_THREAD(c,t,n);
if(THREAD_TYPE(tf) == THREAD_F_WALL)
f = C_FACE(c,t,n);
F_CENTROID(x,f,t);
wf = x[1];
C_CENTROID(cell,c,t);
nc = cell[1];
delta = wf-nc;
temp = C_T(c,t);
tempgrad= (temp - Twall)/delta ;
F_PROFILE(f, thread, position) = k * tempgrad;
end_c_loop_all(c,t)
Yadu krishnan is offline   Reply With Quote
Old   August 31, 2021, 12:55
pakk will become famous soon enough
Apply it in a simple geometry, and see if the results are the same as what you calculate by hand.
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
Old   August 31, 2021, 23:37
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you have a typo
to be
F_CENTROID(x,f,tf);
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Heat Flux versus Wall Heat Flux: inlet - outlet energy, different values jmenendez CFX 1 February 14, 2021 16:55
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Heat flux profile UDF B.Hamada Fluent UDF and Scheme Programming 4 July 29, 2014 09:07
Heat flux profile UDF B.Hamada Fluent UDF and Scheme Programming 11 July 18, 2014 21:39
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 17:44
