UDF to correct the wall-normal fluctuation
Old   October 19, 2021, 16:57
Default UDF to correct the wall-normal fluctuation
imane
zahrae is on a distinguished road
hello!
I m about to model particle deposition using the RSM model combined with the EWT and the DRW to model the particle turbulent dispersion, however, the deposition is dependent on the normal fluctuating velocities thus the RSM needs to be corrected based on experimental data.
the question is which Macro should I use to create my UDF program?
I will be grateful if someone helps me!!
thank you!
Regards.
zahrae is offline   Reply With Quote
Old   August 3, 2022, 09:31
Shuvo Chowdhury
Shuvo_Chowdhury is on a distinguished road
Hello, have you got any solution. I am also stuck at this problem
Shuvo_Chowdhury is offline   Reply With Quote
Ansys CFD-Post Application Error rushiCFD FLUENT 0 March 21, 2021 07:51
How to use a UDF to set the volume fraction in the cells next to a wall? DF15 Fluent UDF and Scheme Programming 33 August 20, 2020 13:36
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 17:30
UDF for fluxes normal to a wall Leverkin FLUENT 0 December 10, 2007 12:04
