UDF for changing density under a sinusoidal function with respect to time |
March 9, 2023, 03:57 |
Mohammad Reza Soufivand
Rep Power: 3 |
Hello everyone,
I am facing a problem with implementing a UDF code, and I would really appreciate it if someone could guide me in this matter. The issue is that I have a two-dimensional square domain with four walls. At a specific point with specific coordinates in this domain, the density changes over time according to a sinusoidal function. Initially, the density is equal to one throughout the domain, and then it spreads like a sin wave from the origin of the specific point. My objective is to extract the pressure fluctuations on a single line and save them in a separate file. To achieve this, I have written a UDF and used three macros. However, I am encountering an error and I am not sure how to fix it. If anyone has experience in this area and can offer some guidance or help troubleshoot the issue, it would be greatly appreciated. Thank you in advance. export.jpg SLDCMPSS.c |
March 10, 2023, 07:03 |
Rep Power: 6 |
i think you need to parallelize your code in order to write data into a single file. You can refer to the example in fluent udf manual (7.9.2. Writing Files in Parallel)
/******************************************************************* This function will write pressures and positions for a fluid zone to a file on the host machine ********************************************************************/ #include "udf.h" # define FLUID_ID 2 DEFINE_ON_DEMAND(pressures_to_file) { /* Different variables are needed on different nodes */ #if !RP_HOST Domain *domain=Get_Domain(1); Thread *thread; cell_t c; #else int i; #endif #if !RP_NODE FILE *fp = NULL; char filename[]="press_out.txt"; #endif #if PARALLEL int size; /* data passing variables */ real *array; int pe; #endif /* Only Serial and Compute Nodes have data on threads */ #if !RP_HOST thread=Lookup_Thread(domain,FLUID_ID); #endif #if !RP_NODE /* SERIAL or HOST */ if ((fp = fopen(filename, "w"))==NULL) Message("\n Warning: Unable to open %s for writing\n",filename); else Message("\nWriting Pressure to %s...",filename); #endif /* UDF Now does 3 different things depending on SERIAL, NODE or HOST */ #if !PARALLEL /* SERIAL */ begin_c_loop(c,thread) fprintf(fp, "%g\n", C_P(c,thread));/* Simply write out pressure data */ end_c_loop(c,thread) #endif /* !PARALLEL */ #if RP_NODE /* Each Node loads up its data passing array */ size=THREAD_N_ELEMENTS_INT(thread); array = (real *)malloc(size * sizeof(real)); begin_c_loop_int(c,thread) array[c]= C_P(c,thread); end_c_loop_int(c,thread) /* Set pe to destination node */ /* If on node_0 send data to host */ /* Else send to node_0 because */ /* compute nodes connect to node_0 & node_0 to host */ pe = (I_AM_NODE_ZERO_P) ? node_host : node_zero; PRF_CSEND_INT(pe, &size, 1, myid); PRF_CSEND_REAL(pe, array, size, myid); free(array);/* free array on nodes after data sent */ /* node_0 now collect data sent by other compute nodes */ /* and sends it straight on to the host */ if (I_AM_NODE_ZERO_P) compute_node_loop_not_zero (pe) { PRF_CRECV_INT(pe, &size, 1, pe); array = (real *)malloc(size * sizeof(real)); PRF_CRECV_REAL(pe, array, size, pe); PRF_CSEND_INT(node_host, &size, 1, myid); PRF_CSEND_REAL(node_host, array, size, myid); free((char *)array); } #endif /* RP_NODE */ #if RP_HOST compute_node_loop (pe) /* only acts as a counter in this loop */ { /* Receive data sent by each node and write it out to the file */ PRF_CRECV_INT(node_zero, &size, 1, node_zero); array = (real *)malloc(size * sizeof(real)); PRF_CRECV_REAL(node_zero, array, size, node_zero); for (i=0; i<size; i++) fprintf(fp, "%g\n", array[i]); free(array); } #endif /* RP_HOST */ #if !RP_NODE /* SERIAL or HOST */ fclose(fp); /* Close the file that was only opened if on SERIAL or HOST */ Message("Done\n"); #endif } |
March 10, 2023, 14:34 |
Rep Power: 3 |
I worked on this problem and modified the UDF. Now I can initialize correctly. Also, I can change density for a region like x<XSS, but when I want to apply a function for varying density at a specific point (XSS, YSS), it doesn't work properly! Even though I changed the point to a small region with 4 nodes, it didn't work correctly, and the density didn't change. What do you think about that?!
March 10, 2023, 14:37 |
#4 | |
Rep Power: 3 |
March 10, 2023, 18:05 |
#5 | |
Rep Power: 6 |
DEFINE_ADJUST(calculate_rp_rms, d) { Domain* d; Thread *t; cell_t c; real rho; real rho_per, sumrp, rp_rms, sl; real maxit = 1600.0; // maximum number of iterations int i, j; FILE *fp; /* Open the output file */ fp = fopen("rp_rms.txt", "a"); /* Get the density value for this iteration */ rho = RP_Get_Real("density", 0, 0); /* Initialize sumrp */ sumrp = 0.0; /* Loop over all cells in the domain */ thread_loop_c(t, d) { begin_c_loop(c, t) { /* Get the cell coordinates */ i = C_UDMI(c, t, 0); j = C_UDMI(c, t, 1); /* Calculate rho_per */ rho_per = C_R(c, t) - rho; /* Calculate sumrp */ sumrp += rho_per * rho_per; /* Write rp_rms to file for i = 1001 to 2000 and j = 50 */ if (i >= 1001 && i <= 2000 && j == 50) { /* Calculate rp_rms */ rp_rms = sqrt(sumrp / ((i - 1001) * j)); /* Calculate sl */ if (rp_rms != 0.0) { sl = 20.0 * log10(rp_rms); } else { sl = 0.0; } /* Write to file */ fprintf(fp, "%d %d %f %f\n", i, j, rp_rms, sl); } } end_c_loop(c, t) } /* Close the output file */ fclose(fp); } Writing files in parallel is done in the following stages: 1. The host process opens the file. 2. Compute node-0 sends its data to the host. 3. The other compute nodes send their data to compute node-0. 4. Compute node-0 receives the data from the other compute nodes and sends it to the host. 5. The host receives the data sent from all the compute nodes and writes it to the file. 6. The host closes the file. |
define_adjust macro, define_init, define_property, udf |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
laplacianFoam with source term | Herwig | OpenFOAM Running, Solving & CFD | 17 | November 19, 2019 13:47 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
