Fluent giving error while click on calculate
Old   November 2, 2022, 05:11
Post Fluent giving error while click on calculate
bilal
hbilal1076 is on a distinguished road
Please senior help me to resolve the shown error.
I will highly appreciate your help.
when I compile UDF and then click calculate, it give this error
Node 0: Process 15088: Received signal SIGSEGV.
job aborted:
[process exited without calling finalize]
----Error analysis----
[0] on DESKTOP-14SMM28
C:/PROGRA-1/ANSYS............................................. ..............., exit code 2
----Error Analysis-----
hbilal1076 is offline   Reply With Quote
Old   November 2, 2022, 22:46
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
most likely you didn't allocate memory for UDMs
or UDF was compiled with errors
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 2, 2022, 22:50
Default Solved the issue
bilal
Yes, after allocating the memory, the problem is solved, thank you.
[TUTORIAL] Run fluent on distributed memory with 2 windows 7 64 bit machines ghost82 FLUENT 54 February 9, 2022 03:32
How does fluent calculate the total enthalpy? bap FLUENT 0 June 22, 2016 10:55
How to calculate the torque in transient Ansys Fluent dynamic FLUENT 3 January 27, 2016 05:10
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 02:00
Fluent validation test for calculate the drag of a car ostervi FLUENT 0 June 12, 2009 12:59
