udf problem (urgent)
Old   April 12, 2009, 12:05
Exclamation udf problem (urgent)
carlo
marttini is on a distinguished road
I am working on a vof case in which i have a tank filled with water up to 50%. i want to define a function to put a sinusoidal velocity for the first 30 seconds. I have tryed with the function showed bellow, but it does not work. I have two question:
Is this the correct way to get variable time?
Do you have to define in your source code, x_velocity if you know that it already exist for fluent program?
#include"udf.h"
real current_time;
real x_velocity;
current_time=CURRENT_TIME;
if(current_time<30.)
{x_velocity=0.3*sin(0.8*current_time)};
else
{x_velocity=0};
thanks in advance
marttini is offline   Reply With Quote
UDF Problem ozgur Fluent UDF and Scheme Programming 18 January 17, 2016 14:40
Pressure profile UDF for unsteady-state problem? Mohsen Keshavarzian FLUENT 2 August 20, 2008 04:22
parallel UDF problem kerem FLUENT 2 June 20, 2006 06:56
Switch problem! using 2 custom udf laws at the same time HP FLUENT 0 September 15, 2004 09:48
UDF variables F1, y / problem with UDF Fabian FLUENT 6 June 2, 2003 10:22
