Parallel DPM Udf problem
Old   May 23, 2011, 04:44
Unhappy Parallel DPM Udf problem
Johney Grey
dust_2 is on a distinguished road
Hi, all! I wrote a DPM UDF for fluent 6.3.26. But I don't know how to edit it to parallel UDF(1CPU 8cores ). Can anyone help me, plz?
By the way, could this udf run on Liunx system?
#include "udf.h"
#include "dpm.h"
#include "math.h"
#include "time.h"
#include "stdio.h"
static int n=0;
double integral(double s) // to generate a parabolic particle distribution
double a=0.0,b=5.0,mid=2.5,y=-0.004*mid*mid*mid+0.3*mid;
for(;fabs(s-y)>1e-6; )
if(s>y)
a=mid;
mid=(mid+b)/2.0;
else
b=mid;
mid=(a+mid)/2.0;
return mid;
DEFINE_DPM_INJECTION_INIT(init_particles,I)
Particle *p;
FILE *fp;
real xm[ND_ND];
double R=0.0, x=0.0, y=0.0, an=0.0,k=0.0;
if(n==0)srand((unsigned)time( NULL ));
k=rand()/(double)(RAND_MAX);
R=integral(k);
an=rand()/(double)(RAND_MAX)*2*3.1415926;
x=R*sin(an)/200.0;
y=R*cos(an)/200.0;
Message ("\n n=%d, k=%f\n",n, k);
n++;
p=I->p_init;
P_POS(p)[0]=x;
P_POS(p)[1]=y;
P_POS(p)[2]=0.0;
Message ("particle position x=%f, y=%f\n", P_POS(p)[0],P_POS(p)[1]);
xm[0]=P_POS(p)[0];
xm[1]=P_POS(p)[1];
xm[2]=P_POS(p)[2];
P_DIAM(p)=5e-6;
P_RHO(p)=1000;
P_MASS(p)=P_RHO(p)*M_PI*pow(P_DIAM(p),3.0)/6.0;
P_FLOW_RATE(p)=P_MASS(p)/0.06;
fp=fopen("e:\\test\\pa.txt","at");
fprintf(fp,"%f %f %f\n",R,xm[0],xm[1]);
fclose(fp);
dust_2 is offline   Reply With Quote
Old   June 10, 2011, 04:12
john
johnwinter is on a distinguished road
for parallel code you should keep
#if !RP_HOST
#endif
and
#if ! RP_NODE
#endif
has to be kept at appropriate places in the code. See UDF manual for more details
johnwinter is offline   Reply With Quote
Old   June 10, 2011, 08:26
Johney Grey
#if !RP_HOST
#endif
and
#if ! RP_NODE
#endif
Thanks for your reply. But I just don't know where to put them. The manual only has one page mentioned about the paralleliztion of DPM model. And it mainly talks about message output.
Old   June 11, 2011, 00:43
john
HI i am not an expert, based on my knowledge i have corrected your code below
#include "udf.h"
#include "dpm.h"
#include "math.h"
#include "time.h"
#include "stdio.h"
static int n=0;
#if !RP_HOST
if(s>y)
a=mid;
mid=(mid+b)/2.0;
else
b=mid;
mid=(a+mid)/2.0;
return mid;
#end if
#if !RP_HOST
Particle *p;
FILE *fp;
real xm[ND_ND];
R=integral(k);
x=R*sin(an)/200.0;
y=R*cos(an)/200.0;
// Message ("\n n=%d, k=%f\n",n, k);
n++;
p=I->p_init;
P_POS(p)[0]=x;
P_POS(p)[1]=y;
P_POS(p)[2]=0.0;
//Message ("particle position x=%f, y=%f\n", P_POS(p)[0],P_POS(p)[1]);
xm[0]=P_POS(p)[0];
xm[1]=P_POS(p)[1];
xm[2]=P_POS(p)[2];
P_DIAM(p)=5e-6;
P_RHO(p)=1000;
#endif
node_to_host_real_3(R, xm[0],xm[1]);
#if !RP_NODE
fclose(fp);
#endif
you may need to change some more look at carefully and change. all the best
Old   June 11, 2011, 10:03
Talking
Johney Grey
#include "udf.h"
#include "dpm.h"
#include "math.h"
#include "time.h"
#include "stdio.h"
static int n=0;
#if !RP_HOST
if(s>y)
a=mid;
mid=(mid+b)/2.0;
else
b=mid;
mid=(a+mid)/2.0;
return mid;
#end if
#if !RP_HOST
Particle *p;
FILE *fp;
real xm[ND_ND];
R=integral(k);
x=R*sin(an)/200.0;
y=R*cos(an)/200.0;
n++;
p=I->p_init;
P_POS(p)[0]=x;
P_POS(p)[1]=y;
P_POS(p)[2]=0.0;
xm[0]=P_POS(p)[0];
xm[1]=P_POS(p)[1];
xm[2]=P_POS(p)[2];
P_DIAM(p)=5e-6;
P_RHO(p)=1000;
#endif
#if !RP_NODE
fclose(fp);
#endif
WOW! Thanks a lot! I'll try it.
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 07:24
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
A UDF Problem in Parallel Mode Jun FLUENT 1 October 26, 2011 12:49
problem loading UDF in parallel fluent Tim FLUENT 12 July 12, 2008 12:59
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 09:02
