MergeSort with a twist - Scheme
Old   November 9, 2011, 18:48
Default MergeSort with a twist - Scheme
Daniel Yacouboff
ydan87 is on a distinguished road
Hello there,
I would like to implement MergeSort numbers given in a list, but following the following algorithm:
1) break the given list into list of lists, with a single number in each list (i.e. from (5 2 6) to ((5) (2) (6)))
2) iterate over the list of lists - merge each 2 adjacent lists and create a list of the results (example: from ((5) (2) (7) (1)) to ((5 2) (7 1)) or from ((5) (2) (7)) to ((5 2) (7)))
3) repeat step 2 until there is only one element in the list, which is the sorted list.
4) return it.
here's my suggestion code, what's wrong with it ?
(define (fasterMergeSort lst)
  (define (break lst)
    (if (null? lst) ()
        (cons (list (car lst)) (break (cdr lst)))))
  (define (merge lst1 lst2)
    (cond ((null? lst1) (car lst2))
          ((null? lst2) (car lst1))
          ((< (car lst1) (car lst2)) (list (car lst1) (merge (cdr lst1) lst2)))
          (else (list (car lst2) (merge lst1 (cdr lst2))))))
  (define (iter lst)
    (cond ((null? lst) ())
          ((= (length lst) 1) lst)
          (else (cons (merge (car lst) (cadr lst)) (iter (cddr lst))))))
  (cond ((null? lst) 'no-list)
        (else (let* ((lstBroken (break lst)) (mergeBrokenLst (merge (car lstBroken)(cdr lstBroken))))
                (if (= (length mergeBrokenLst) 1) mergeBrokenLst
                    (iter mergeBrokenLst))))))
Thanks in advance
ydan87 is offline   Reply With Quote
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
Implementation of QUICK scheme Romuald Skoda Main CFD Forum 11 November 6, 2017 21:20
AUSM scheme ? Central Scheme boling Main CFD Forum 7 January 7, 2016 02:41
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
