January 18, 2012, 17:42 |
parallel running issue
xiaokang
Dear all,
I compiled a parallel udf and work very well in local PC. When I ran it in cluster with parallel mode, it claimed a lot of warns at the first time. Then i built and load udf again in cluster(the warns still claimed).And then i read the same case for the second try, nothing claim~~everything seems ok! So, is that ok? I heard if you run your case in parallel, you must make your "build path" as a "absolute path", or you must put your udf into every node your case use....... All of that I didn't do, but just build udf again and read case again, seems everything goes well! I really worry about there do have some error but just no claim to me. ps, I use fluent13 version. Great thanks! xkyan |
udf parallel |
OF 2.0.1 parallel running problems | moser_r | OpenFOAM Running, Solving & CFD | 9 | July 27, 2022 03:15 |
RSH problem for parallel running in CFX | Nicola | CFX | 5 | June 18, 2012 18:31 |
parallel running - error while loading shared libraries: | seami | OpenFOAM Installation | 1 | December 9, 2011 04:39 |
Running PimpleDyMFoam in parallel | paul b | OpenFOAM Running, Solving & CFD | 8 | April 20, 2011 05:21 |
Running dieselFoam in parallel. | Palminchi | OpenFOAM | 0 | February 17, 2010 04:00 |
