plain orifice atomizer
Old   May 15, 2012, 01:42
Default plain orifice atomizer
leila
lili is on a distinguished road
hi
I want to model a plain orifice atomizer. in fluent help it says the required parameters are:
nozzle diameter
nozzle length
radius of curvature of the inlet corner
upstream pressure
downstream pressure
viscosity
liquid density
vapor pressure
while in set injection properties panel the required parameters are: the position of injection point (x,y,z), axis (x,y,z), temperature, flow rate, vapor pressure, injector inner diameter and orifice length, corner radius of curvature, constant A, azimuthal start and stop angle.
why these parameters are different from those exist in help? and what is constant A? is it: Ca=3+L/3.6d (L orifice length and d orifice diameter)
lili is offline   Reply With Quote
plain orifice atomizer with heterogeneous reaction? lili FLUENT 1 May 12, 2012 07:04
Spray Modelling-Plane Orifice Atomizer Model bharat05 FLUENT 0 May 3, 2012 02:36
2D axisymmetric mass flow rate for the plain orifice atomizer jwillie2000 FLUENT 2 September 17, 2010 05:43
Flow past orifice aurel Main CFD Forum 0 January 27, 2009 06:46
azimuthal angle in plane orifice atomizer model sina FLUENT 0 September 23, 2008 01:23
