Meshing for multiphase flow
Old   May 17, 2012, 16:14
Default Meshing for multiphase flow
joshi20huregina is on a distinguished road
Hi
I am trying to mesh a rectangular channel using Ansys workbench that will be used for multiphase flow using VOF method with oil and water. However, the mesh I create constantly results in high courant number in Fluent. I am using variable steeping in Fluent with the courant number set to 1 and minimum time step of 1e -07 and maximum time step of 1e -04. The courant number greatly exceeds 1 and the results become unrealistic. I created an automatic mesh by Ansys workbench which gives satisfactory results but I couldn't make the mesh finer near the wall. So to fix that I am manually meshing the channel in Ansys workbench by defining the number of edge divisions but it just isn't working. I have tried coarsening and refining the mesh but it doesn't work either. I have attached my mesh picture, can someone please help me??? My boundary condtions are velocity inlet, pressure outlet, and a contact angle at the wall. The flow is incompressible and laminar. Thank you very much for the help. If you need any more info then please let me know.
Sincerely,
Harsh
joshi20huregina is offline   Reply With Quote
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 06:12
Meshing for Mutliphase free surface flow MatzeMas ANSYS 2 August 7, 2009 05:06
FLOW 3D Meshing AMP FLOW-3D 6 October 1, 2008 11:07
