How to import table into Fluent
Old   June 20, 2012, 18:10
Default How to import table into Fluent
George Pichurov
jorkolino is on a distinguished road
I need to import field data into fluent. The data contains X, Y, Z coordinates of a variable and the values of the variable at these points. I want to use this variable as a source term, for example. Regards
jorkolino is offline   Reply With Quote
Old   August 27, 2012, 11:32
George Pichurov
Update: Here is a method to use. Actually two, one of which should be more straightforward:
1. Use File-> Interpolate
2. Arange your data file in a format described in Fluent 6.3 chapter 4.13.2
An example of an interpolation file is shown below:
2
2
34800
3
x-velocity
pressure
y-velocity
-0.068062
-0.0680413
The format of the interpolation file is as follows:
The first line is the interpolation file version. It is 1.0 for FLUENT 5 and 2.0 for FLUENT 6.
The second line is the dimension ( 2 or 3).
The third line is the total number of points.
The fourth line is the total number of fields (temperature, pressure, etc.) included.
From line 5 is a list of field names. To see a complete list of the field names used by FLUENT, select the display/contours text command and view the available choices for contours of. The list depends on the models turned on.
Then comes a list of x , y , and (in 3D)  z coordinates for all the data points.
In the end is list of the field values at all the points in the same order as their names. The number of coordinate and field points should match the number given in line 3.
Cannot import ANY ICEM hex core into Fluent v6.3!! Robert Perry FLUENT 11 April 12, 2012 04:30
How to import Autodesk Inventor .ipt file into ANSYS FLUENT? soetommy FLUENT 0 September 27, 2011 00:35
How to import CAD into Fluent (Design Modeler)? shadyenany FLUENT 2 August 9, 2011 20:14
Import CFX def into Fluent eric_wang FLUENT 0 April 18, 2011 13:14
Data import in Fluent?! Bart Horsten FLUENT 3 February 22, 2010 13:05
