fluent mpi
Old   June 19, 2012, 14:45
Default fluent mpi
nikos
nikolaous is on a distinguished road
Hello guys,
I was wondering which are the required applications for executing fluent in parallel? I use linux, and more specifically fedora 16 version. Is it needed any specified version of mpi and where is it advisable to be installed? I'm asking this becasuse i use mpi through PETSc which isn't installed in a common folder for example usr/ ...
Thanks in advance for your help.
nikolaous is offline   Reply With Quote
Old   July 5, 2012, 16:28
Casey
meangreen is on a distinguished road
I have found that fluent runs pretty well in parallel out of the box as long as you have the correct licenses. You can not run a simulation on more than 4 processors with a serial license (you will be using 4 licenses). There is lots of stuff around the fluent website/documentation about what to do about compilers. With RHEL 6, fluent in parallel just ran out of the box for me.
meangreen is offline   Reply With Quote
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
heat transfer with RANS wall function, over a flat plate (validation with fluent) bruce OpenFOAM Running, Solving & CFD 6 January 20, 2017 06:22
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 07:46
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
