Geometry Generation Fail
Old   July 26, 2012, 20:52
Question Geometry Generation Fail
Amanda Maria Bizzinotto Ferreira
AmandaMBF is on a distinguished road
Send a message via Skype™ to AmandaMBF
Good Night everyone,
I'm trying to do a fluid simulation over an Eppler 423 airfoil. I'm following this tutorial https://confluence.cornell.edu/displ...oil+-+Geometry.
I could generate the curve, the surface, the grid and the grid surface. But then I have to create two lines, one horizontal line dividing the grid in half and one vertical line dividing the grid in half. I can create the horizontal line but I cannot create the vertical line. When I try to generate the line by selecting the sketch and generating the curve I have the error: "Boolean operation failed".
Does anybody know how can I fix it?
Thank you
AmandaMBF is offline   Reply With Quote
Old   July 27, 2012, 02:02
Marion
Marion is on a distinguished road
Could you specify what software you are using?
It looks like your problem is more geometry/meshing related, therefore maybe you should post in the appropriate section of the forum to get an answer?
Marion.
Marion is offline   Reply With Quote
Old   July 27, 2012, 07:45
Default Thanks
Hello Marion,
Yes it is geometry related. I'm new on this forum so thanks, I'll post it in the apropriate forum.
By the way I'm using Ansys Workbench - Fluent to do the simulation and I'm creating the geometry there.
Thank you very much,
Amanda
boolean, fluent 12.1, geometry simulation
Question about Geometry vs. Meshes EphemeralMemory ANSYS Meshing & Geometry 2 December 8, 2016 13:02
Importing CAD geometry and Editing edges to match Ahmed CFX 15 March 21, 2016 12:39
Geometry and mesh generation in OpenFoam pokeng OpenFOAM Pre-Processing 1 October 28, 2011 21:40
3d geometry mesh generation mach13 ANSYS Meshing & Geometry 10 September 10, 2009 11:03
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
